DIY for Serpentine Belt / Fan Belt? - Honda Pilot - Honda Pilot Forums
Old 07-02-2008, 04:17 PM   #1 (permalink)
Default DIY for Serpentine Belt / Fan Belt?
I tried the search and was surprised that I could not find a DIY for the fan belt. The belt on my '03 Pilot is starting to squeak and I am looking to change it out here in the near future.
Thanks in advance!
Chupula is offline   Reply With Quote
Old 07-05-2008, 11:42 AM   #2 (permalink)
There are two belts on the '03 Pilot. The smaller of the two is the Power steering belt. iirc, To change this belt the passenger side engine mount needs to be removed. There are two mounting bolts that need to be loosened along with a tensioning bolt/nut at the top of the P/S pump. The other belt drives the A/C and Alternator with an automatic tensioner and is released by using a 14mm box wrench turning in the clockwise direction I believe. It may be easier to remove the lower splash guard from the wheelwell/under the engine to gain access.
~ Lay & Vina ~
- 2003 Nighthawk Black Pearl, EX-L 4WD
- 1991 Honda CRX Si
- 1978 Honda CVCC wagon - 1.6L DOHC ZC swap
Layspeed is offline   Reply With Quote
