Brake pad/fluid change - Honda Pilot - Honda Pilot Forums
Old 06-03-2008, 01:15 PM   #1 (permalink)
rlb
Default Brake pad/fluid change
I'm going to replace the front and rear brake pads myself but am going to have someone else change/flush the brake fluid. They will be done at separate times. Would it be better for me to replace the pads before or after the brake fluid is changed? I'm thinking I should do it after so as not to push back dirty fluid into the master cylinder when compressing the piston. Thanks.
2003 Honda Pilot EX-L Sage Brush Pearl #23,718 - Side Steps, Crossbars, Cargo tray, Cargo net.
rlb is offline   Reply With Quote
Old 06-03-2008, 01:28 PM   #2 (permalink)
Default Re: Brake pad/fluid change
Change pads first and then fluid soon after.
Old 06-03-2008, 05:49 PM   #3 (permalink)
Default Re: Re: Brake pad/fluid change
Agreed. What difference does it make if you push the dirty fluid back in if you're replacing it anyway? I suppose if you wanted to get really carried away you could bleed out the REALLY dirty fluid when you do the pads and then replace the fluid later.
Old 06-04-2008, 04:30 AM   #4 (permalink)
rlb
Thanks guys.
