Maint. Minder question - Honda Pilot - Honda Pilot Forums
Old 05-18-2008, 09:03 AM   #1 (permalink)
Question Maint. Minder question
I Change my oil and reset the Maint. minder at around 10% to 20%.
When resetting the maint. minder (oil) back to 100%, does that reset other items like tranny fluid changes or any other normal maint. items back as though they have been done? 2006 Pilot
jmilling is offline   Reply With Quote
Old 05-18-2008, 12:25 PM   #2 (permalink)
Default Re: Maint. Minder question
Yes. When you reset the system it assumes you did all the services that the MM indicated needed to be done. Those services are reset and others that are ticking keep ticking.
Old 05-26-2008, 08:04 AM   #3 (permalink)
speedlever's Avatar
What happens if you do a double reset? IE, nothing is showing and you do a reset? Nothing? Changes everything back to 0?
--speedy
2006 Pilot EXL-RES Billet Silver
2008 Ridgeline RTS Billet Silver
speedlever is offline   Reply With Quote
