Power steering fluid change needed? - Honda Pilot - Honda Pilot Forums
Old 03-15-2008, 06:48 PM   #1 (permalink)
jarizzo's Avatar
Default Power steering fluid change needed?
Hi all -
I recently installed the Honda power steering cooler and an aftermarket transmission fluid cooler so I can tow my pop up camper. In removing the old PS cooler, I noticed the fluid was a dark tan color. Refilling the reservoir, the Honda PS fluid is almost clear. Does the PS fluid get dirty/burnt/sheared enough to require changing at any particular interval, or is the color change nothing to worry about? I have no negative symptoms or anything, I just like my Pilot and want to keep it in top form for as long as possible. Thanks in advance.
Cheers!
John
jarizzo is offline   Reply With Quote
Old 03-15-2008, 07:26 PM   #2 (permalink)
I don't like discolored fluids, but would go by smell.
If it is at all brunt smelling I would change it.
If it is dark enough to not be transparent, or if it is cloudy at all, I would change it.
If it is just ambered a bit and if clear and smells normal, I would not worry.
Old 03-15-2008, 07:40 PM   #3 (permalink)
jay
jay's Avatar
How does new power steering fluid smell?
EDIT: What should the fluid smell like?
Old 03-15-2008, 07:46 PM   #4 (permalink)
jarizzo's Avatar
I'll do a blindfolded smell comparison test between the existing fluid and the remainder of a new bottle that I have. Take the Honda Power Steering Fluid Challenge today! :-D
John
Old 03-15-2008, 08:04 PM   #5 (permalink)
John
I thought almost everyone who plays with cars knows what burnt ATF or power steering fluid smells like.
It smells "Burnt"!
