![]() Join Date: Jun 2007
I have started using a torque wrench to install the oil pan drain bolt, which is set to 29 fl/lbs. I am afraid that I will strip the threads on the oil pan if I attempt to do this using a ratchet because I tend to be a little heavy handed when it comes to tightening nuts and bolts. I am considering installing a Fumoto drain valve to do away with this task altogether.
Has anyone ever stripped out the threads on their oil pan? How much torque would it take to actually do this? I am sure that some quick oil change places use powerful air tools to remove/install this bolt, so perhaps my fears are unfounded. |
#2 (permalink) | |
i tighten till my biological torque wrench says its tight enough.
Then you will get a feel for what is right. Most bolts don't need near the force most people apply.
Olde Timer Administrator
Good luck!
'10 Honda Pilot EX-L '11 Ford Mustang GT/CS '12 Yamaha XT1200Z Enjoy Life Today Yesterday Is Gone Tomorrow May Never Come |
It should still give you a decent idea of how much is too much.
#9 (permalink) | |
#11 (permalink) | |
#12 (permalink) | |
You chose the word "average". I was simply trying to answer the question.
#13 (permalink) | |
#14 (permalink) | |
But, I guess you cannot acknowledge or accept when someone posts clarification that may be a little different than your thinking. Oh well........
#15 (permalink) |
My experience is that torque specs for oil drain bolts tend to be too high for two reasons: 1) many oil pans are "slotted" on one side of the drain boss to encourage more complete draining which tends to weaken the boss and make it spread as you approach the rated torque; and 2) most torque ratings are a function of bolt size and tend to assume dry/clean thread; typically a drain bolt is very well lubricated.
Both of these factors mean that the margin of safety for you to over-torque a bolt in this application are less than normal. Also keep in mind that torque wrenches are typically not calibrated very well and 30 ft-lb may actually be 35 or 40. Finally, drain bolts are steel and pans are aluminum and you know who will win. The fact that tens of companies make oversize/self-tapping drain bolts to remedy the problem of people stripping them indicates to me that it's not that tough to do. Although I've never done it, I once had an R1 motorcycle which was in for a recall and since it needed an oil change, I had the shop do the change. Yep, their trained mechanics stripped it and they had to ante up with a new oil pan. I've changed oil hundreds of times on a variety of vehicles without either one loosening in service or stripping, so I stick with my own calibrated feel for the wrench and how the bolt tightens up, but if you use a torque wrench, I'd tend to err on the low side a bit. - Mark |
