![]() Join Date: Feb 2008
7,500 mi/12,000 km Scheduled Maintenance
Recommended service for your 2003 Honda Pilot: Replace engine oil. Rotate tires (follow pattern on page 311 in your Owner's Manual). |
15,000 mi/24,000 km/1 yrs Scheduled Maintenance
Recommended service for your 2003 Honda Pilot: Replace engine oil. Rotate tires (follow pattern on page 311 in your Owner's Manual). Replace engine oil filter. Check parking brake adjustment. Inspect brake hoses and lines (including ABS). Check all fluid levels, condition of fluids, and check for leaks. Inspect exhaust system.* Inspect fuel lines and connections.* Inspect cooling system hoses and connections. Inspect front and rear brakes. Inspect tie-rod ends, steering gear box and boots. Inspect suspension components. Inspect driveshaft boots. * = See information on maintenance and emissions warranty, last column, page 273 in your owner's manual. Replace rear differential fluid. (Necessary for proper break-in of the VTM-4 rear differential.) |
22,500 mi/36,000 km Scheduled Maintenance
30,000 mi/48,000 km/2 yrs Scheduled Maintenance
Recommended service for your 2003 Honda Pilot: Replace engine oil. Rotate tires (follow pattern on page 311 in your Owner's Manual). Replace engine oil filter. Check parking brake adjustment. Inspect brake hoses and lines (including ABS). Check all fluid levels, condition of fluids, and check for leaks. Inspect exhaust system.* Inspect fuel lines and connections.* Inspect cooling system hoses and connections. Inspect front and rear brakes. Inspect tie-rod ends, steering gear box and boots. Inspect suspension components. Inspect driveshaft boots. * = See information on maintenance and emissions warranty, last column, page 273 in your owner's manual. Inspect and adjust drive belts. Replace dust and pollen filter. Replace air cleaner element. Replace rear differential fluid. (Necessary for proper break-in of the VTM-4 rear differential.) |
37,500 mi/60,000 km Scheduled Maintenance
45,000 mi/72,000 km/3 yrs Scheduled Maintenance
Recommended service for your 2003 Honda Pilot: Replace transmission fluid. Replace engine oil. Rotate tires (follow pattern on page 311 in your Owner's Manual). Replace engine oil filter. Check parking brake adjustment. Inspect brake hoses and lines (including ABS). Check all fluid levels, condition of fluids, and check for leaks. Inspect exhaust system.* Inspect fuel lines and connections.* Inspect cooling system hoses and connections. Inspect front and rear brakes. Inspect tie-rod ends, steering gear box and boots. Inspect suspension components. Inspect driveshaft boots. * = See information on maintenance and emissions warranty, last column, page 273 in your owner's manual. |
52,500 mi/84,000 km Scheduled Maintenance
60,000 mi/96,000 km/4 yrs Scheduled Maintenance
67,500 mi/108,000 km Scheduled Maintenance
75,000 mi/120,000 km/5 yrs Scheduled Maintenance
82,500 mi/132,000 km Scheduled Maintenance
90,000 mi/144,000 km/6 yrs Scheduled Maintenance
#15 (permalink) |
97,500 mi/156,000 km Scheduled Maintenance
