Oil Change - Honda Pilot - Honda Pilot Forums
Old 02-13-2008, 08:47 AM   #1 (permalink)
late49er's Avatar
Default Oil Change
Hello Everyone,
I am getting ready to do my first oil change on my pilot and was wondering about the special tool Honda says is needed to remove the oil filter.
The service manager at my local dealer says their technicians simply use a wrench that is easily found at a parts store.
It seems to me that the filter could simply be removed by hand and then hand tightened until it fits snug.
Am i missing something here?
Thanks,
Late49er
late49er is offline   Reply With Quote
Old 02-13-2008, 09:15 AM   #2 (permalink)
ctobio's Avatar
The factory oil filter has been, in my experience, absurdly tight on most cars. The Pilot was a pleasant surprise. I easily removed it with a strap wrench.
That said, I got one of those strap wrenches- you know the kind- that has a belt loop. Something like this:
You won't be able to loosen it by hand easily, and you should never tighten an oil filter with a tool.
The traditional metal oil filter wrenches usually can't accommodate the small diameter of our filters. I'm not a big fan of the cap style filter wrenches, as I'm never sure of the consistency of the fluting between filter brands.
Constantino Tobio
Vehicles in the driveway:
'73 VW Fastback, Marina Blue
'94 John Deere LX176
Old 02-13-2008, 01:40 PM   #3 (permalink)
late49er's Avatar
Hello Ctobio,
Thanks for the response. I will go get a wrech like you posted.
This seems like a fairly straightforward job. Have to say i am really surprised by the smallness of the oil filter. Given its small size I wonder if that speaks to changing it more often than the book says.
late49er
Old 02-13-2008, 03:31 PM   #4 (permalink)
ctobio's Avatar
Originally posted by late49er
[B]
This seems like a fairly straightforward job. Have to say i am really surprised by the smallness of the oil filter. Given its small size I wonder if that speaks to changing it more often than the book says./B]
It is a straightforward job. I do recommend the following:
Get one of those long transmission funnels and remove the filter with the funnel underneath and directing into your recovery pan. Else it will drip oil all over the place, including part of the subframe. I usually unscrew the filter partway, let it and the engine drain as much as possible from there, and then spin it out until it falls in the funnel.
As for the size of the oil filter, sure, it's about as large as the filters my lawn tractor uses. Honda recommends changing every other oil change, which is probably sufficient. A quality oil filter will last a remarkably long time in an engine. That said, oil filters are cheap, and the $5 a filter costs me extra every other oil change isn't a hardship- I've spend more on dumber crap.
Constantino Tobio
Old 02-13-2008, 05:25 PM   #5 (permalink)
Default I realize that...
today you can change filter every other OC; but I can't bring myself to be that thrifty. Every oil change, new filter. Creature of habit, I guess.
'05 w/Navi - Traded in at 136K for..
'08 EX
beer4799 is offline   Reply With Quote
Old 02-14-2008, 12:33 PM   #6 (permalink)
evarsallona's Avatar
Location: Evergreen Valley of San Jose area of California
Garage
Send a message via Skype™ to evarsallona
Default D.I.Y. Oil Change
Drive up on ramps and turn the wheels all the way to the right
inside the right fender pull and hold forward( using a bungee cord) the black plastic engine shied next to the oil filter for more room.cut a 2 lither plastic bottle in half (length ways)and cut the bottom off then use it like a funnel, (bottom side up) and put it all the way up behind the oil filter to keep the oil from getting on the engine and frame and let drain into a drain pan
January '06 Honda Pilot EX-2WD Metallic Silver
Grille inserts/Turn signal mirrors/All side windows tinted/Auto door locks/Hand brake audio warning/Dash mat/Auto mirror/compass//Carpet and rubber mats/Side rails/rear over load shocks/Cargo tray/Net/Cover/Roof rack cross bars/carrier Tray/Lock gas cap honda key/Michelin C/T tires/Wheel locks/Valve caps honda logo/Splash guards/Full size spare/Frame braces/EX & V6,vtec.Emblems/Towing package/Hitch carrier/Bumper guard/Rerouted exhausts outlet.
evarsallona is offline   Reply With Quote
Old 02-15-2008, 09:32 AM   #7 (permalink)
late49er's Avatar
Hello Everyone,
thanks for all the good tips.
One question. Can one simply leave the pilot grounded and do the oil change?
Thought I could simply crawl under like I did with my Jeep.
Thanks,
late49er
Old 02-15-2008, 11:13 AM   #8 (permalink)
Send a message via AIM to Mikeyworks Send a message via Yahoo to Mikeyworks
I just did a DIY change on my '07 Pilot last night. This was the second oil change and the dealer did the first one free.
Now I can't figure out how to get the oil life to go back to 100%. It still says 15%.
Any recommendations?
I have been working on my own cars for years and while I check stuff when I do changes, I use a top-sider oil changer to reduce the amount I need to climb under the car. Therefore I never removed the drain plug. Does this have anything to do with the reset (stretch but thought I would mention it).
mikey
Mikeyworks is offline   Reply With Quote
Old 02-15-2008, 12:32 PM   #9 (permalink)
Garage
Default Oil Change Indicator Meter
Owner's Manual page's 232 and 233 Maintenance Indicator
Resetting the Engine Oil Life Display
Your dealer will reset the display after completing the required maintenance service. You will see "OIL LIFE 100 %" on the information display the next time you turn the ignition switch to the ON (II) position.
If maintenance service is done by someone other than your dealer, reset the maintenance minder as follows:
#1-Turn the ignition switch to the ON
#2-(ID position.Press the Select/Reset knob until
the engine oil life indicator is
displayed.
#3- Press the Select/Reset knob for more than 10 seconds. The engine oil life and the maintenance item code(s) will blink.
#4-. Press the Select/Reset knob for more than 5 seconds. The maintenance item code(s) will disappear, and the engine oil life will reset to "100."
Old 02-15-2008, 12:42 PM   #10 (permalink)
Garage
Default Oil Change (Ramps)
Hello Everyone,
Thanks,
late49er
Yes: You can leave it on the ground but your jeep might be a little higher, the ramps are just for convenience
Old 02-15-2008, 01:03 PM   #11 (permalink)
I change my oil without ramps and without even turning the wheels to get to the oil filter. It's just a matter of groveling around on the garage floor a bit.
Old 02-15-2008, 01:24 PM   #12 (permalink)
Garage
Hello Mark
Yes, I have done it down on the ground before, but I find it more convenience up on ramps and turning the wheels to the right. So it's easy to get in from the side to the oil filter.
Old 02-15-2008, 11:02 PM   #13 (permalink)
you might want to search under FUMOTO VALVE if you plan on keeping the
Pilot a long time and changing your own oil. It replaces the oil drain bold
with a sea cock type valve.
2006 Pilot EX 4WD, Born in Bama,
crvrefuge is offline   Reply With Quote
Old 02-16-2008, 04:45 AM   #14 (permalink)
... that hangs down and could easily get wacked off if you do any serious snow or off-road driving. Sorry, I don't think for most drivers saving 30 seconds during oil changes is worth the risk.
Old 02-16-2008, 11:14 AM   #15 (permalink)
Mark, the valve doesn't actually hang down at all:
