Can someone please tell me where the tach test connector is on the 04 pilot. looked on the wall near the driver shock tower and only see the orange connector for the brake fluid.
Not sure what you are trying to accomplish - are you looking for a digital rpm reading, the OBDII connector is under the dash near the driver right knee position. If you have an OBDII diagnostics tool you can get the tach reading from there. If you do not own this tool most of the large after market parts stores will hook up to the OBDII for you, some for free.
Do a search for 'scan guage' on this forum (I have one in my Pilot), Im sure it will suffice your needs to check rpm and timing. Hope this helps.
Fall down 3x, get up 4. Night Hawk Black 2004-EX;Splash Guards,Towing/Roof Rack bars/full Spare,Magelan Nav/Cargo Tray & Net,110V 1.3A Power/Winter mats/Privacy Windows/Vortex Valve/Large carrier/Wide rear view mirror/led lights wired to dimmer 2 @ centre and 2 inside arm rest/grill led's/instaled DTRL/3rd row seats replaced w/built in cargo area - better mileage/Scan Guage in centre console/remote starter/ earview back up cam. LOVE my Pilot |
how about this?
Honda Pilot 2005 Remote start / Security / GPS Wire/Function Colour Location/Description Polarity PASSIVE ANTI-THEFT YES TRANSPONDER SEE NOTES 12 VOLTS White Ignition switch harness + IGNITION Black/yellow Ignition switch harness + ACCESSORY Yellow Ignition switch harness + STARTER Black/white Ignition switch harness + TACH Blue/silver dots 1-pin plug near master brake cylinder AC LOCK Red/white On blue plug in passenger kickpanel - UNLOCK Red/black On blue plug in passenger kickpanel - DOORPIN Black/white Behind on/off switch on right of st. column - HOODPIN Yellow At hood latch in engine compartment - FACTORY ARM Pink/black* In 8-pin connector behind glovebox - FACTORY DISARM Green/blue* In 8-pin connector behind glovebox - BRAKESWITCH White/black At switch above brake pedal + PARKLIGHTS Red/black In driver's kickpanel + HORN Lt.green/blue At steering column - TRANSPONDER IGNITION Yellow/black At 7-pin plug on Ignition switch assembly + TRANSPONDER DATA 1 Red At 7-pin plug on Ignition switch assembly data TRANSPONDER DATA 2 Blue At 7-pin plug on Ignition switch assembly data TRANSPONDER GROUND Brown/yellow At 7-pin plug on Ignition switch assembly - Vehicle notes PLEASE NOTE: This vehicle is equipped with a TRANSPONDER passive anti-theft system. Please refer to the proper security diagram before any remote start installation. * These wires will also control doorlocks, but do work when ignition is on. You must still make the connections to the doorlock wires. Note: The information on this sheet is provided to you on an as is basis with no representation or warranty of accuracy whatsoever. It is the sole responsibility of the installer to check and verify any circuit before connecting to it. Only a computer safe logic probe or digital multimeter should be used. Wiremagic.com Corporation and/or any associated or unassociated individual or corporation who furnishes this document and/or software assumes absolutely no liability or responsibility whatsoever pertaining to the accuracy or currency of the information supplied. The installation in each and every case is the sole responsibility of the installer performing the work and Wiremagic.com Corporation and/or any associated or unassociated individual or corporation assumes no liability or responsibility whatsoever resulting from any type of installation, whether performed properly, improperly, or in any other way. The information supplied is a guide only.
I am connecting my remote starter to the system. I know what wire color I am looking for and I have even seen a picture of one on an '05 but it does not seem to be in the same place in the '04. Am I wrong?
another one!
DIRECTWIRE™ WIRING INFORMATION - HONDA / PILOT / 2004 / Remote Start 12volts white + ignition harness Starter black/white + ignition harness Second Starter N/A Ignition black/yellow + ignition harness Second Ignition N/A Third Ignition N/A Accessory yellow + ignition harness Second Accessory white/black + ignition harness Keysense blue/black (required) - ignition harness Power Lock blue/green - passenger mux unit Notes: Meter these wires while turning the key in the passenger door key cylinder. The passenger mux unit is attached to the passenger side fuse box in the passenger kick panel. Power Unlock black/red - passenger mux unit Notes: Meter these wires while turning the key in the passenger door key cylinder. The passenger mux unit is attached to the passenger side fuse box in the passenger kick panel. Lock Motor white/blue 5wi passenger mux unit Notes: The passenger mux unit is attached to the passenger side fuse box in the passenger kick panel. Unlock Motor yellow 5wi passenger mux unit Notes: The passenger mux unit is attached to the passenger side fuse box in the passenger kick panel. Also found in a green plug on the front of the driver side fuse box. Parking Lights+ red/black + driver kick panel Parking Lights- red/yellow - headlight switch Hazards same as turn signals Turn Signal(L) green/white + steering column Turn Signal(R) green/yellow + steering column Reverse Light green/black + driver kick panel Door Trigger black/white - interior light switch on dash Dome Supervision lt. green - interior light switch on dash Trunk/Hatch Pin common with door trigger Hood Pin yellow - hood switch or Notes: Also found at the driver mux unit, which is attached to the driver side fuse box in the driver kick panel. Trunk/Hatch Release N/A Power Sliding Door N/A Factory Alarm Arm arms with lock Factory Alarm Disarm disarms with unlock Disarm No Unlock blue - driver door key cylinder Tachometer blue ac tach test connector Notes: The tach test connector is a 2 pin connector on the driver side fender. Wait to start N/A Brake Wire white/black + brake pedal switch Parking Brake green/red - parking brake switch Horn Trigger lt. green/blue - steering column Memory Seat 1 N/A Memory Seat 2 N/A Memory Seat 3 N/A Immobilizer Bypass Module: Required: Yes Type: Transponder Part #: 555H, 556U, or 555U Notes: N/A
you can use a voltmeter to check and put it on AC.
for more info:http://www.the12volt.com/installbay/....asp~TID~40350
Ok. Found the tack line on the green plug on the driver's kick. It was blue w/ grey dots. It is easier to ID the line using AC HZ mode than just monitoring volts since I can identify RPM changes with throttle more clearly.
Now I just need to locate the line inside the cab for the hood pin and I will be good to go. I didn't want to have to go though the firewall anyway. Thanks. |
Please help!!!! I think i found the tach wire your talking about but im not sure. Do you or anyone else here have a picture or can you or someone here take a picture for me? Please! I also need help finding the hood pin wire. Iv tried every yellow wire in the drivers and passagers kick. Please help! Pictures would be nice but a description would work. Iv tries searching everywhere. Thanks!!
