LinkBack | Thread Tools |
Rating:
#91 (permalink) |
WOW was that easy. I used a 9/16 x 3/8 x 12 clear tubing, though the dip stick tube fits a 1/2 I wanted it tighter so it would not leak.
Using a pair of needle nose pliers I stretched the tubing for the dip stick tube end with the help of a hair dryer, on the other end attached a funnel that will stay permanently. Drained out about 3.5- 3.75 quarts, first change at 57K, fluid did not look to bad, yes dark but not that much pic up on the drain bolt. My dealer sold the quarts @ $7.07 and didn't even have a replacement washer as he said, the guys in back don't use one. I pulled the washer off gently cleaned it as the edge had a build up and was worried it may not seal well. Also heated it up gently with a torch hoping to gain back some elasticity unless it went plastic. CAUTION I tried this with the oil washer and since they are aluminum it melted off the hook I had it on when I didn't pay attention.
2005 Pilot EXL Sage Brush |
#92 (permalink) |
Any reason why you didn't use the fill-hole? For Pilots without the oil-jet mod (certain '04s and later), the fill hole is easy to get to and you can just use a long funnel for the fluid refill.
#93 (permalink) | |
I found the ATF change actually easiler then the VTM fluid change.
#94 (permalink) | |
#95 (permalink) | |
Thanks for the great write up. Pictures made it very easy. I just changed my trans fluid using your method. It worked great! Thanks Again! |
#96 (permalink) |
What about the drain/fill plugs in transfer case? They appear to have the same 3/8" plugs as in the rear. Not much info in the manual. These are not the drain/fill plugs for the auto trans.
Thanks.
2006 Pilot EX-L : Roof rack, hitch, side steps, bug deflector, mud guards, fender flare kit, bull bar, driving lights, cargo tray, Akebono pads + Brembo blanks, trans cooler 2006 Accord EX-L Sedan V6MT : Mud guards, 20mm TL rear sway bar, trunk tray, Akebono pads + Brembo blanks 2006 CRF250R 1985 TRX125 1987 Mustang GT |
#97 (permalink) |
This might be the easiest job I've done on any vehicle. I used a heat gun on the plastic tubing and stuck my pinky in it to expand it and it fit just fine around the dipstick hole.
Thanks for step by step.
07 Civic LX 04 Pilot EX 02 Accord SE 08 TRX500FM 01 CBR 929RR - gone 99 CBR 600 F4 - gone 80 CM 400T - dead |
#99 (permalink) | |
Not sure if it's the exact same on the 09 but no need to drive it up on ramps.
#100 (permalink) |
I've been lurking around here for a while, and am amazed at all the great info. Two weeks ago I bought an 03 with 60k. It seems pretty common for folks to change out the ATF whenever they change their oil. I was just wondering if that means every 3500 or 7000?
#101 (permalink) | |
Sounds a bit much to change it that often. Do you really change the oil every 3500? My engine oil still looks pretty clean at that point and the ATF is clean for sure.
If you really want to do it anyway I'd say you can easily wait till 7000 or maybe change the ATF every other oil change. Quote:
#102 (permalink) | |
#103 (permalink) | |
I use the severe maintenance sched, and after approx 3,600 miles mine is dirty. I also change the tranny fluid (4 qts) every other oil change. Again I find the stuff that comes out is not the "garnet" colour of the stuff going in. So just a paraniod precaution. The oil change on the Pilot is so easy, so it is not big deal.
#104 (permalink) |
The blackness of the oil has nothing to do with its lubricating qualities.
#105 (permalink) | |
I figure the '03 weak point is the tranny, so I over do it. Not only that, I have only towed twice, and I have the tranny cooler and p/s cooler installed.
