LinkBack | Thread Tools |
Rating:
#31 (permalink) |
The Honda Pilot does not have a CVT (continuously variable transmission).
#33 (permalink) |
LOVE MY HONDAs
Nope, no filter. Your'e in luck, just drain and fill.
2005 Honda Pilot EX, 2005 Honda Accord EX-L "DON'T EVER GIVE UP!" ---JB(me) "When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return.' ----Leonardo da Vinci |
#34 (permalink) |
Nice job and thanks for posting the instructions and pics. I'm going to do the same thing before I start towing the camper this spring.
The manual says an ATF drain/fill will use 3.6 quarts, so that pretty much jives with what you guys have seen. Are there any thoughts out there about the torque specs for the bolts and Honda's recommendation to use a new crush washer every time the bolts are loosened? Or does everybody use the same washer and just tighten it until your hand hurts? I just don't want to strip anything. That could get real expensive real fast. Thanks... John |
#35 (permalink) |
LOVE MY HONDAs
I just reused the washer. No leaks at all. If you are really are wanting the torque I will look in the morning as my manual is out in the car and its 10PM. I will post the torque first thing in the morning.
..............alright I was tired of sitting on the couch so I went out and got the manual. Here is what is says about both bolts: Drain bolt 18x1.5mm 49Nm (5.0kgf.m, 36 lbf.ft) Fill Bolt 24x1.5mm 44n.m (4.5kgf.m, 33lbf.ft)
#36 (permalink) | |
LOVE MY HONDAs
#37 (permalink) | |
I removed the ATF filler plug on top of the trans to fill it up again instead of using the dipstick tube. I have a funnel with a long hose that was perfect for the job. About 3.75 quarts filled it up. The drain plug magnet was pretty crusty with metal particles. Hopefully between the new fluid and a clean magnet the trans will stay in good shape for a long time. Next stop, differential fluid change... Much appreciated Armystrong. Cheers! ![]() John |
#40 (permalink) | |
LOVE MY HONDAs
I love my Pilot so I want the transmission to last and optimizing how clean the fluid remains for the life that I have the Pilot is why I chose to integrate this change cycle into my maintenance routine.(Keep in mind this is just my routine as I maintain a meticulous maintenance schedule on my 05 Accord and 05 Pilot, to date no problems at all on either vehilce) Sorry it took me so long to respond.
#42 (permalink) | |
LOVE MY HONDAs
Take Care
#43 (permalink) |
I changed the transmission oil. A little over 4 quarts came out I believe. 30,900 miles on it. I was expecting a redder oil. It was more dirty than I expected. All I had was a 1/2" tube and it worked. I will probably change it the next oil change to see the color. The trans drain bolt was not on super tight which surprised me. One whack with a hammer and it got loose. I did not even whack it hard. I changed the rings too.
1) It is best to "check" the trans oil when the oil is cold? 2) Do you change the VTM fluid? How often do you do so? I changed mine today and it was the 2nd time. It had 10,000 miles on it and the red color was good. When I change my VTM, I drive the front wheels up on ramps and then drained and fill. After filling, I back it up on ramps to top it off. Is this a good method? 3) Do you change the power steering fluid? If so, how often? 4) How often do you change the motor oil? Where is the trans refill bolt? I did not find it. How long can you store transmission fluid? Thanks for this post. |
#44 (permalink) | |
LOVE MY HONDAs
Answer in order: #2 I change my VTM fluid every 14,000 miles or sooner. 14k because I usually do my oil changes every 7,000 miles. (Mobil 1 5W20) Your method of changing the fluid is similar to mine. Almost exactly the same. Don't change a thing and 10,000 mile changes on VTM may be alittle early. Everytime I have changed mine at 15k it looks good. #3 I have never changed the power steering fluid. I am not sure what the intervals are on the power steering but when it says to do it, I will. And if there is not a good post started on changing the PS fluid then I will take some pictures and post a DIY. #4 I change my Mobil 1 synthetic fluid every 7,000 miles or every six months. It usually turns out to be every six months. #5 If you look at the pictures on page one of this thread, you will see the picture of the service manual shows it is up and to the left of the drain hole. At least that is what it looks like. I have never loosened that bolt and don't plan to either. Really I am not sure how long you can store xmsn fluid. I am not even sure if there is an expiration date on fluid that is stored in its container. Good question. Hope all this helps. Jim
#45 (permalink) | |
