I searched the forum and understand this has been discussed extensively. But I have some doubts about using front hook and rear vertical bar (close to rear differential) for central jack points, as neither are flat surface to put a jack on.
Below pictures show alternative jack points (red rectangle boxes) I thought are safe, but certainly need your inputs. |
![]() ![]() ![]() ![]() Join Date: Dec 2003
The rear center point is fine. There is also one in the front, I've used both several times with no issues.
I haven't used the front hook, just because I don't see the need with the jack point right there in the center. |
See here for details.
That is why I need alternative jack points. I probably miss something here, but it doesn't appear right to me to use the protruding front hook and rear vertical bar as the jack points. I thought you need a stable/flat/sturdy surface. Thanks. |
Front center (seems like a tow hook) and rear center (behind the differential) is still the best jack point according to the shop manual. One lift with a SUV jack will let you put two jack stands (for each side stock jack point) at once. Every jack's lift cup will hold the jack point perfectly. I have been doing this since first tire rotation. Working great. As I said, I just followed the direction of the shop service manual.
2005 Pilot EX, Sage Brush with Runing Board |
And I don't have shop/service manual myself, it could be I completely misunderstand your point, you actually put jack saddle on the area close to hook, not directly under the front hook, even that area is quite small as well. I am lost, .
#9 (permalink) | |
Until we got a Pilot, I always wondered what that thing was for because I would see it every time we got behind one.
Don't use the stock jack come with your car, though. The stock jack can only be used at the stock jack points (two under front door and two under back door).
#11 (permalink) | |
If you don't believe it that's fine. Don't try and overengineer this, jack up the car from the jack points and sleep well at night, it's really that simple. |
I use the same front and rear jacking points (mentioned by those who have replied) all the time.
I just changed my VTM-4 fluid this past weekend and had a chance to get a close look at the rear strip of steel/hook. I could have sworn that it said had the word "JACK" stamped on its side. I never really see the side of the front hook during oil changes because it's a bit recessed within a bunch of plastic. If you're curious enough, you should take a look for yourself. And like others mentioned, I always use a hydraulic floor jack, not the OEM one.
#13 (permalink) | |
Go out and try it. Don't put the jack beside the lift points, put RIGHT UNDER the lift point, they fit very nice at others have mentioned. Make sure you block the tires with some wooken blocks or chocks. You can do it. If you have no confidence (which is okay we all start some where), go to a smaller tire store and just hang around and watch what they do, or ask them about where the points are. They know. Don't go to Walmart or any of those quick places.
#14 (permalink) | |
This board is the best, I love it (and my Pilot). |
