Changed my tranny oil tonight. Filled it back through the dip stick hole. Everything worked out great. I drained just shy of a gallon of fluid out for those curious. That Honda oil is exspensive
I think I will look at buying it online if possible for next time.
2003 Honda Pilot EXL, Color-SS, Sunroof, Fog Lights, Tow Package, Cargo Rack, Splash/Mud Guards. Purchased 8-13-07 |
Feedback Score: 1 reviews
Good job! Why through the dipstick hole?
I have change mine twice and I just fill at the filler bolt. I don't remember what year yours is. And.... a gallon sounds about right for a drain/fill procedure
Filled through the dip stick hole because I have an 03 with the recall to the transmission. I didn't want to fool with trying to pull that oil jet pipe thing out and doing damage.
You'll save yourself a 'ton o' money if you try to do most of your own maintanence.
Rip Tide Dude!
OK. New to the board and have seen a few refrences to filling but no one mentions where the drain bolt is or what you do to drain it. Is it similar to the rear differential drain and fill procedure? I am trying to get away from the dealers for most of these maintanance issues.
The drain 'bolt' is pretty much under the driver's feet. Of course underneath the car.... It has a recess in it to slip in a 3/8" drive to loosen it up. Lefty loosey... Make sure you get the fill bolt loose BEFORE you drain, just in case you run into a problem loosening the filler bolt. Pretty much all the '03's and some of the '04's had a recall and modification to the tranny via the fill hole. On those years, they have to fill in the dipstick tube. Mine was made in May '04 and didn't have the mod done at the factory, so I fill mine up via the fill hole, not the dipstick hole. Just like changing engine oil..... drain/notice how much you took out/fill that much back in. Use only Honda ATF fluid. Do that 3 times to get a full flush of all the old fluid. Drive a couple of miles between each drain/fill. If you only do it once, you leave a lot in the tranny and torque converter. Should take about 12 quarts if I remember correctly to do it 3 times. Fluid is $4-$5 per quart. $50 - $60 total. The dealer charges more than that and I'm sure they only do it once. Good luck, it really is easy..... I'm due to do mine next weekend ( my 3rd time to do a tranny flush ) at 45,000 miles. Cheap insurance because I use my Pilot to tow frequently.
#9 (permalink) | |
Look down the thread a bit.... I took a picture of the tranny filler bolt. If you see yours on your 05, double check the owner's manual and then fill 'er up through that hole. I just am not sure about the 05s fill procedure.
#10 (permalink) | ||
#12 (permalink) | |
It is very $$ and time consuming to the the 3X for a full flush. I interpret the OM as stating that a flush is only necessary when some other fluid has been put in the tranny instead of Honda ATF. I tow a boat and pop up camper a LOT with my Pilot and really pay attention to the condition of the fluid when I drain it. So far... the fluid had come out clean and doesn't smell. The only thing I find is some sludgy stuff on the magnetic drain plug. But even then, it's not excessive. Save yourself money and just have 4-5 quarts of fluid handy when you drain and fill it one time. People have reported getting anywhere from 3.5 quarts per drain up to 4.5 quarts (like I did last week) when draining the tranny fluid.
#14 (permalink) | |
I think that's what a dealer typically charges per quart of ATF on their shelves. I've ordered my Honda ATF off the internet where it's cheaper but shipping is usually not included. I also ordered other parts at the same time to make the most of the shipping charges.
#15 (permalink) | |
