#16 (permalink) |
www.bernardiparts.com
They will ship fluids, some dealers won't. Trans fluid is $4.65/qt, probably cheap enough to cover the shipping charge. I've bought from them, so far very reliable. |
#17 (permalink) |
Just finished my first Trans fluid change and it worked out great. Picked up the ATF at Honda and headed to the garage with the dif post's I had printed out. Picked up a funnel at Harbour Freight with an extension and it worked. The extension end fit perfectly over the dip stick opening and poured right in. Was going to try to remove jet kit but it seem more difficult to get too. Dipstick opening worked great/fast.
Thanks for all the info. |
#18 (permalink) |
In regards to the picture at http://hondapilot.org/forums/showthr...ght=white+bolt posted by jestmaty, the drain filler plug is above the blue bolt? I have a 2005 EXL, is it best to get the atf at this bolt? If so, will it drain enough oil so I would not have to do it 3 times? From what I saw, most are not changing the atm filter? Isn't that a bad idea?
#19 (permalink) |
Feedback Score: 1 reviews
Yep, it is a 17mm bolt. The biggest one in the picture....
The OM for the '04 only recommends the fill/drain 3X if you've put something other than Honda tranny fluid in it for some reason. No one on HP.org has said their OM has listed the filter as a serviceable item. Just about ANY parts place like Autozone, O'Reilly, Advance, Walmart etc... have for a couple of bucks a long black funnel for sale. It is about 15 or 16" long and fits perfectly in the filler hole. Just make sure that it is snugly wedged down into the fill hole, because if it comes out, you'll make a giant mess. I know from experience.
#21 (permalink) |
I edited my post, read it again. I have gotten away from 3X drain/fill.
My Pilot has the tow package with tranny/power steering coolers so I feel more comfortable that the fluid doesn't get so hot. My guess is that about 1/3 of the total tranny fluid capacity drains out when you just do a 'one time drain' of the fluid.
#22 (permalink) |
Changed my AT fluid today (51K mi
) using a power flush system (it's awesome living across the street from a mechanic who has all the great toys ). Started by running some BG AT cleaner in it first, then flushing. The fluid coming out was DIR-TY!! Followed up with BG AT conditioner as well.Very minimal hassle (did have to remove the plastic cowling? under the front part of the engine to access the lines), no mess & didn't have to fuss with the X4 drain/fill routine! I've used this system on my past vehicles (GM, Honda) with good results. PS-Got my AT fluid through Bernardi.com. Even with shipping, a case of fluid was alot less than my local stealership at almost $8/qt.
2005 Pilot EX-L Desert Rock Metallic w/ lime green Jackson Fun whitewater kayak on top & 2 cool dogs inside! |
#23 (permalink) |
you are not supposed to power flush the transmission. best of luck to you...
#24 (permalink) |
Where's the service bulletin on that?? I'd love to show it to the dealer, who tried to sell me the same service. I'll let you know if the transmission craps out
#25 (permalink) |
I have a funnel I made out of an old fuel filter from my VW (a large can) and a length of 5/16" vinyl hose. It works quite nicely.
#26 (permalink) | |
- Mark |
#27 (permalink) | |
This is in the 2003 Service Manual, page 14-154. It also indicates that you use biodegradable flushing fluid. Hope that helps Have you noticed any change in shifting? Is it any smoother?
#28 (permalink) | |
#29 (permalink) |
I've put about 300 miles on it since the fluid change....still as smooth as it ever was...no change in the shifting, power, etc. Wasn't hoping for anything better, just for it to keep working fine.
The 'cleaner' additive was put into the old fluid, vehicle driven for a little, then flushed w/ new trans fluid. The conditioner went in after the new fluid was ran through it. Same stuff they sell at the dealership... I've seen a couple other forums out there raking the Honda transmissions across the coals, from the '03 to an '08 w/ <5K miles on it....what gives? Is this an albatross nobody talks about? Would like to hear some thoughts...
#30 (permalink) | |
We complain about every squeak and little irritant on this forum, so nothing like that would go unpunished! I change the 1X tranny drain every other oil change (around 7,000 miles). The stuff just seems dirty. So this way it seems to keep its nice colour and smell. Smoothest shifting vehicle I've ever owned, but I used to have Explorers!
