Tire wear/rotation - Honda Pilot - Honda Pilot Forums
Old 08-12-2007, 11:05 AM   #1 (permalink)
Really OnHonda12 now!
Default Tire wear/rotation
2006 Pilot with 49,000 Kilometres on it. Recently had the truck into the dealer for routine service. Just noticed that when they rotated the tires, they put the pair that was almost down to the wearbar on the front. Is this normal or should the worn ones be on the rear? Not impressed with only getting 50 Kilometres out of a set of tires. I will likely be getting rid of the Pilot this fall or in the spring so I don't want to sink money into tires needlessly. Likely to get another Pilot or back to 'Oddy. Then I'd have to change my name to OnHonda12!
On a Sabatical from Honda at present. Hope to get back into the Honda market in a year or so. Doing the leasebusters.com thing by assuming short leases with low km's and high cash incentives. Tired of lease mileage restrictions yet don't want to buy just for that sake either.
OnHonda11 is offline   Reply With Quote
Old 08-12-2007, 11:30 AM   #2 (permalink)
Default Re: Tire wear/rotation
Why is one pair much worse than the other?
Have you been rotating them regularly?
Old 08-12-2007, 11:33 AM   #3 (permalink)
Default Re: Re: Tire wear/rotation
To be perfectly honest, I haven't paid too much attention to them. I get the truck regularly serviced at the dealer. I know in the spring, they "seemed" pretty much even in terms of wear from front to back. All of the sudden, they're bald on the front. Should they be on the front or the rear. I know usually on a front wheel drive vehicle, the worn ones always go on the rear.
Old 08-12-2007, 11:51 AM   #4 (permalink)
When you rotate tire you "rotate" them.
The backs end up on the front and the fronts end up on the back.
If you rotate then often enough then wear is even and you don't have to worry about this kind of thing.
Old 08-12-2007, 01:56 PM   #5 (permalink)
Thanks N'Jay. Back to the original question though; Where should the beefier tread beon the Pilot in particular... on the front or the rear? I would think the front being front wheel drive. Right?
Old 08-12-2007, 02:16 PM   #6 (permalink)
Yeah, I would put the "better" tires up front.
Old 08-12-2007, 03:55 PM   #7 (permalink)
In general you want your "sticker" or "better" tires in the rear.
The reason if if you suddenly loose traction in the front it is MUCH more forgiving and easier to regain control then if you suddenly lose traction at the rear.
Old 08-12-2007, 04:33 PM   #8 (permalink)
xGS
xGS's Avatar
[http://www.tirerack.com/tires/tirete....jsp?techid=52].
Although this article covers where to install a new pair of tires, it still answers the question as to where the tires with greater wear should be mounted.
Old 08-12-2007, 04:44 PM   #9 (permalink)
heh heh, he said "member"
Even though the above linked article says otherwise, I personally would also put the better tires on the front, especially on a front wheel drive car. I'd rather deal with my back end swinging than my front end "washing out" - I'm pretty comfortable drifting a car... (YMMV!).
"If You Open It, You Get The WHOLE Can." - SEB Lt "Petey"
Do not go gentle into that good night... ...Rage, rage against the dying of the light. - Dylan Thomas
Samuel2003 is offline   Reply With Quote
Old 08-12-2007, 06:54 PM   #10 (permalink)
I like people who THINK like you. If you have had the rear end come around unexpectedly you might KNOW different.
Old 08-12-2007, 08:26 PM   #11 (permalink)
Are you ASSuming that I have never had my rear end come around? I've had a "little bit" more than your average driver's training. I'm very comfortable with how I prefer to set up and drive a car (front or rear wheel drive). Like I said before, YMMV. Me, I'd rather lose my back end than my front...
Old 08-13-2007, 10:34 AM   #12 (permalink)
BigDozer66's Avatar
Send a message via Yahoo to BigDozer66
The new tires should be installed on the REAR whether it is a front or rear wheel drive.
Years ago it was always called 'fishtailing' or 'powersliding' but the kids now seem to call it 'drifting' but it is a situation where the rear of the car isn't tracking behind the front for whatever reason.
If your 'front' tires (the ones they just put on the front) are now worn out then it is time to replace at least 2 of them.
If you only want to replace 2 at a time then replace the Rear 2 and in 5,000 miles (KM's?) then replace the other 2 when you have them rotated.
I prefer to replace all of mine at the same time to keep the rotation and balancing even. My delaer rotates and balances them every 5,000 miles for free.
From what I gather from most Pilot owners these GY Integrity's are a 40,000 tire at best and in that case I will be replacing them at 30,000 miles or so.
I don't like "Slick Willy Slide-a-Lot" tires on any vehicle I own or drive.
I rotate my tires every 5,000 miles and check the air pressure every other time I fill up with gas.
Edited to change information that was posted and isn't correct.
BigDozer66
2007 Pilot EX-L RES, Taffeta White, WWong Side Step Pads, Pads & Lens Protectors, Rear Splash Guards, Tint, WeatherTech Window Deflectors & Cargo Liner, Honda Side Steps, DealExtreme LED's, Billet Lower Grille, BF Goodrich Long Trail T/A's
BigDozer66 is offline   Reply With Quote
Old 08-13-2007, 10:38 AM   #13 (permalink)
Thanks everyone for your help and input on this.
Old 08-13-2007, 11:06 AM   #14 (permalink)
Originally posted by BigDozer66
The new tires should be installed on the front whether it is a front or rear wheel drive.
If it is FWD then the better tires will be under the heavier load and will be the driven tires in a loss of traction situation.
If it is RWD then the better tires will be on the front under the heavier load but also on the steering tires in a loss of traction situation.
Please find me one industry reference that recommends your approach.
Old 08-13-2007, 11:11 AM   #15 (permalink)
Medic721's Avatar
N_Jay I am with you 100%. FWD or RWD better tires in the rear.
-Mike.
