105,000 mile service - Honda Pilot - Honda Pilot Forums
Old 07-11-2007, 02:51 PM   #1 (permalink)
Default 105,000 mile service
What are people paying for the replacement of the timing belt?
What are people paying for the Valve adjustment?
What are people paying for the replacement of the spark-plugs?
Old 07-11-2007, 03:02 PM   #2 (permalink)
rockman19762001's Avatar
I paid $800.00 for the timing belt which included a new water pump. New Spark Plugs, Valve adjustment, New Air and Cabin Filters, Flushed the brake fluid and Power Steering fluid and then a oil change VTM-4 and automatic transmission fluid change ran $400.00 so the total bill was $1200.00 this included sales tax of 8.5 percent.
Old 07-12-2007, 03:48 AM   #3 (permalink)
Just out of curiousity N_jay, are you already at 105K or getting close to it? From what I've read on the forum, you seem quite capable of tackling this service yourself
But ~$1200 seems about right for all of the services mentioned by rockman19762001, you're looking at about $600 in parts alone.
~ Lay & Vina ~
- 2003 Nighthawk Black Pearl, EX-L 4WD
- 1991 Honda CRX Si
- 1978 Honda CVCC wagon - 1.6L DOHC ZC swap
Layspeed is offline   Reply With Quote
Old 07-12-2007, 06:41 AM   #4 (permalink)
Just tooo damn busy!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 07-12-2007, 11:40 AM   #5 (permalink)
GreenMachine's Avatar
Did I read that right, $400 for those three services? Seems very high.
Old 07-12-2007, 01:37 PM   #6 (permalink)
I had forgotten about the VTM-4 and automatic transmission fluid also being done and edited it in the list of other services in that sentence.
New Spark Plugs, Valve adjustment, New Air and Cabin Filters, Flushed the brake fluid and Power Steering fluid and then a oil change VTM-4 and automatic transmission fluid change ran $400.00, this entire list of work cost $400.00 dollars.
Old 07-12-2007, 02:00 PM   #7 (permalink)
dustino8's Avatar
If I recall correctly, I think my timing belt replacement was about $350 Canadian, which did not include the water pump. However, the water pump is $87 from Majestic Honda site, so $800 seems a bit high.
2007 Toyota Tundra
Old 07-12-2007, 03:19 PM   #8 (permalink)
That's a good deal for $400. $800 for a timing belt and water pump replacement seems high, but then again, I haven't had that service done yet. I might not be looking forward to it. Come on Honda, timing chains in your new engines.
Old 07-12-2007, 05:12 PM   #9 (permalink)
The timing belt is the only thing I have not liked about Hondas, but many of the imports use timing belts. So, when you buy a new Honda, you are signing up for at least one repair bill running into hundreds of dollars. All I can tell you is that my local independent mechanic that I use for all my repairs on any car or truck I own. Would not take on replacing the timing belt, He said removing one of the nuts on the crank case spindle or something like that (I am not a mechanic). Was a 1 1/4" nut or something big like that and he never wanted to mess with another Honda timing belt ever again. Mark the mechanic said take it to Honda, you will be much happier with the work and the bill. Mark up to that point has never not wanted to work on any car or truck I owned. So, I thought if he did not want to do it I would go with his recommendation.
Old 07-13-2007, 10:24 AM   #10 (permalink)
I think the K series engines have timing chains.
Old 07-14-2007, 10:01 PM   #11 (permalink)
CHADC880's Avatar
actually the timing belt is a fairly easy task for the somewhat mechanically inclined. However one major point already spoken sort of,
The crankshaft pulley bolt is a muther%#$%()$% to get loose. In fact I yet have been able to get it done with a wrench or lets say you need a high powered impact gun.
But if you take your Honda to a qualified quality Honda repair center which many towns have them ( X-Honda Dealer Employees that got tired of Honda and the main manager screwing them over) Honda Repair shops, They do these on a daily bassis. I think a V-6 timing belt change is $500.00 OTD including waterpump, crank and cam seals. He only charges $25 to $30.00 to do the VTM-4 fluid replacement. But he did say he would never do a trailer hitch install on the Pilot, he stated the coolers can be a pain to replace and honda allows not much time for the $$ to do the entire install.
I would think $800 to $900.00 should be a norm for the 105,000 service.
Chad C
Greenville, SC
2009 Honda Pilot EXL
CHADC880 is offline   Reply With Quote
Old 07-15-2007, 05:13 AM   #12 (permalink)
An ody owning friend decided to trade his 100k mile vehicle rather than pay the cost of that service. He bought another ody for 40k and is as happy as a clam.
Old 02-18-2009, 02:21 PM   #13 (permalink)
Angry $2180.35 Quote for 105K Service!
I e-mailed a service manager at the Honda Dealership I have used since I bought my 2003 HP in 2002 for a quote on the 105K service, including the timing belt, water pump, 3 belts, etc. I am including his response. I am amazed at how high this quote is. Has anyone else seen anything close to this?
Here is the Dealer's quote, which itemizes the services to be performed:
105,000 miles/ 168,000 km/ 7 years - $2180.35 total plus taxes (tax on parts only).
Use the Severe Conditions schedule if the vehicle is driven MAINLY in Canada or in any of the following conditions; if only OCCASIONALLY driven in these conditions, use the Normal Conditions schedule.
Severe Driving Conditions
· Driving less than 5 miles (8 km) per trip or, in freezing temperatures, driving less than 10 miles (16 km) per trip.
· Driving in extremely hot over 90ºF (32ºC) conditions.
· Extensive idling, or long periods of stop-and-go driving, such as a taxi or a commercial delivery vehicle.
· Trailer towing, driving with a roof rack, or driving in mountainous conditions.
· Driving on muddy, dusty, or de-iced roads.
Do the items in parts A, B, C, D, E, F, and G as required for the mileage/time interval listed.
o Replace engine oil, every 3,750 miles (6,000 km) or 6 months.
· Capacity: without oil filter 4.4 l (4.7 US qt).
o Replace engine oil filter, every 3,750 miles (6,000 km) or 6 months.
· Capacity: with oil filter 4.8 l (5.1 US qt).
o Check front and rear brake, wear, every 7,500 miles (12,000 km) or 6 months.
· Check pads and discs for wear (thickness), damage, and cracks.
· Check calipers for damage, leaks, and tightness of mount bolts.
· Check brake linings for cracking, glazing, wear, or contamination.
o Rotate tires, and check tire inflation and condition, every 7,500 miles (12,000 km).
· Follow the pattern shown in the Owner's Manual.
o Inspect tie rod ends, steering gearbox, and gearbox boots, every 7,500 miles (12,000 km) or 6 months.
· Check rack grease and steering linkage.
· Check boots for damage and leaking grease.
· Check fluid lines for damage and leaks.
o Inspect suspension components, every 7,500 miles (12,000 km) or 6 months.
· Check bolts for tightness.
· Check condition of ball joint boots for deterioration and damage.
o Inspect driveshaft boots, every 7,500 miles (12,000 km) or 6 months.
· Check boots for cracks and boot bands for tightness.
o Replace air cleaner element, every 15,000 miles (24,000 km).
· Only in dusty conditions, if not use normal condition.
o Check parking brake adjustment, every 15,000 miles (24,000 km) or 1 year.
· Number of clicks (4 to 6) when the parking brake pedal is pressed with 441 N (45 kgf, 99 lbf) of force.
o Lubricate all hinges, locks and latches, every 15,000 miles (24,000 km) or 1 year.
· With Honda White Litium Grease.
o Inspect brake hoses and lines including ABS, every 15,000 miles (24,000 km) or 1 year.
· Check the master cylinder, proportioning control valve, and ABS modulator for damage and leakage.
o Inspect all fluid levels and condition of fluids, every 15,000 miles (24,000 km) or 1 year.
· Automatic transmission fluid (ATF-Z1).
· VTM-4 differential fluid.
· Power steering fluid.
· Brake fluid.
· Windshield washer fluid.
· Engine coolant.
o Inspect exhaust system*, every 15,000 miles (24,000 km) or 1 year.
· Check catalytic converter heat shield, exhaust pipe, and muffler for damage, leaks and tightness.
o Inspect fuel lines and connections*, every 15,000 miles (24,000 km) or 1 year.
· Check for loose connections, cracks, and deterioration; retighten loose connections and replace damaged parts.
o Check lights and controls, every 15,000 miles (24,000 km) or 1 year.
· Check function of interior, and exterior lights and position of the headlights.
o Replace VTM-4 rear differential fluid, first replacement at 7,500 then at 15,000 miles (12,000 km, then 24,000 km) or 6 months, then every 15,000 miles (24,000 km) or 1 year.
· Capacity: 2.64 l (2.79 US qt), use Honda VTM-4 differential fluid.
· Follow this schedule for rear differential fluid replacement if you use your vehicle for off-highway driving, trailer towing, mainly in stop-and-go driving. Otherwise, use the fluid replacement schedule in the Maintenance Schedule for Normal Conditions.
o Replace timing belt, and Replace water pump, Replace accessory belts, every 105,000 miles (168,000 km) or 7 years.
o Inspect the valve clearance, every 105,000 miles (168,000 km), otherwise adjust only if noisy.
o Replace spark plugs, every 105,000 miles (168,000 km).
· Use PZFR5F-11 (NGK) or PKJ16CR-L11 (DENSO).
o Inspect idle speed.
· Idle speed: 730±50 rpm, in N or P position.
Windy City Mike is offline   Reply With Quote
Old 02-27-2009, 12:26 AM   #14 (permalink)
dirk877's Avatar
Question
I am up to the 100k service on my 2005 Honda Pilot.
This is what I am considering for the 100k service (sorry for the caps).
100K HONDA PILOT SERVICE - PER SCHEDULE FOR NORMAL CONDITIONS: (105K)
INSPECT DRIVE BELTS
REPLACE DUST AND POLLEN FILTERS
REPLACE AIR FILTER
REPLACE SPARK PLUGS
INSPECT VALVE CLEARANCE
REPLACE AUTOMATIC TRANSMISSION FLUID
REPLACE VTM DIFFERENTIAL FLUID
INSPECT IDLE SPEED
REPLACE TIMING BELT / INSPECT WATER PUMP
REPLACE ENGINE COOLANT? CHECK SERVICE RECEIPTS
REPLACE BRAKE FLUID? CHECK SERVICE RECEIPTS
PER MY REQUEST:
REPLACE POWER STEERING FLUID
REPLACE THERMOSTAT
REPLACE PVC
CHECK TPMS SERVICE LIGHT ON
RESET GENERAL SERVICE LIGHT ON
I am going to submit estimates to several dealerships in the Colorado Springs/Denver Colorado areas.
I do not know of any reliable independent mechanics here and it is easier for me to just leave it at the dealership and get a free car for the day or two.
Any input or information appreciated.
Cheers
2005 Honda Pilot EX
148,362 Miles
dirk877 is offline   Reply With Quote
Old 02-27-2009, 11:06 PM   #15 (permalink)
I'm getting my timing belt package done at the honda dealer for $666(what an odd number...)
it includes
Timing Belt Package-replacement of:
-timing belt
-water pump
-all belts
-cam seals
-crank seals
-anti-freeze 1 gallon
-inspect hoses
all the other maintenance services i will be doing them myself because these are realtively quite easy and most of you guys can do it too because there are many DIYs covering it.
-air filter
-Automatic tranny fluid
-oil change +filter
-spark plugs
-cabin air filter
I do have a few questions though:
HTI=how to inspect
1.HTI idle speed?
2. HTI valve clearance?
3. HTI tie rod ends, sterring gearbox, boots
4. HTI driveshaft boots
5.HTI brakes hoses and lines
6.HTI cooling system hoses+connections
7.HTI exhaust system(sounds straight forward though...)
8. HTI fue line and connections?
basically, how do i perform all the "inspect etc" on the 105k service the manual says?
kevinssf is offline   Reply With Quote
