oil filter maintenance.. - Honda Pilot - Honda Pilot Forums
Old 06-11-2007, 12:19 AM   #1 (permalink)
Banned
Default oil filter maintenance..
When will you know that you need to change the oil filter? Is it only the oil leaking the only hint for it? The Honda oil filter was not that good when my dad got his car, he just got it from my uncle. Does it need the usual replacement or some fixing are fine?
Need a solution to this problem. Thanks.
john garett is offline   Reply With Quote
Old 06-11-2007, 01:03 AM   #2 (permalink)
I'm not sure what you are trying to ask. You should change the oil filter every time you change the oil. The oil filter should NEVER be leaking any oil under any circumstance while it's on the vehicle.
I still don't understand what your problem is. Are you saying you have an oil filter that is leaking now? If so, replace it ASAP!
By the way, drinking and surfing the internet isn't a good idea.
humanoid is online now   Reply With Quote
