air filter change - Honda Pilot - Honda Pilot Forums
Old 05-21-2007, 09:40 AM   #1 (permalink)
jzw
Default air filter change
Hi there,
I went thru almost all the posts on this board regading air filter change yesterday and thanks for all the tips i was able to remove the screws. I don't think they were bolted on too tight, it is just they were rusted and stuck. Anyway, my question is how one can take off the top cover of the air filter housing completely. The most I could do is to lift the cover just enough to swap the filters. I want to clean the inside of the air filter housing...
jzw is offline   Reply With Quote
Old 05-28-2007, 01:49 AM   #2 (permalink)
rockman19762001's Avatar
Buy some rust buster it will free up the stuck screws.
Old 05-28-2007, 05:43 PM   #3 (permalink)
giwan1259's Avatar
Send a message via Yahoo to giwan1259
Default air cleaner housing
Its not so much they rust but all the vibration makes them tighten and they should be tight.
Now you should be able to unscrew them fully and they will NOT drop out. My understanding is the screw is held in place and can't be removed (easily) hence now worry about it falling in.
2005 Pilot EXL Sage Brush
giwan1259 is offline   Reply With Quote
Old 05-29-2007, 08:21 PM   #4 (permalink)
jzw
I was able to unscrew them fully. i just don't know how to take off the top cover completely so that i could clean the housing. anyway, i changed the filter.
Old 05-30-2007, 06:57 AM   #5 (permalink)
giwan1259's Avatar
Default Filter Cover Screws
I can't remember exactly on how I did it last time but the screws will NOT come out completely. They will release the top and bottom part of the filter cover so you can pull them apart. Make sure you check for another latch as well.
