1st oil change @7k miles -- 3.25qt out, 4qt in? - Honda Pilot - Honda Pilot Forums
Old 04-19-2007, 12:29 PM   #1 (permalink)
t00mies's Avatar
Send a message via AIM to t00mies
Default 1st oil change @7k miles -- 3.25qt out, 4qt in?
hello all --
just checking on what you guys are seeing when you do your oil changes.
i did my first oil change last night at 7k miles.
only 3.25 quarts came out. i know there is residual oil in the oil filter, and maybe coating the insides of the engine, but i left the car in the garage for several days already.
i was able to put in 4qts, maybe just a little more when i put new oil in. the dipstick shows that i am right at the upper end of the hash marks. i ran the engine for a minute in the garage and checked it this morning... it is still at the upper end of the hash.
unfortunately, i didnt check where the oil was on the dipstick before i did the oil change, so i dont know if i was on the low end or waaay below. (maybe i didnt get all the oil i was supposed to get when i bought the car??)
how much oil are you guys able to drain out of the car when you do your oil changes?
thanks,
t00mies
2007 2WD EX-L w/nav
1999 Nissan Maxima SE
t00mies is offline   Reply With Quote
Old 04-19-2007, 02:26 PM   #2 (permalink)
I never measure the old oil on any of my vehicles when I do an oil change. At most, I check the dipstick to see if there's significant oil consumption before I start.
Surprisingly, the filter holds quite a bit of oil. I prefilled the oil filter last time I changed it and was able to put about 1/2 a quart in after letting the media soak up as much as possible.
1995 Yamaha FZR600
Old 05-03-2007, 08:41 PM   #3 (permalink)
Nathan @ NBO's Avatar
I don't think it's abnormal to have less come out then in. Was the car jacked up? Warm when you changed the oil? I bet an easy half a quart could be coating all the internals, so I wouldn't worry about it. I would start worrying when your car is blowing black smoke
<a href="http://www.neverburnout.com">NBO HID Kits and HID Bulbs</a><br>
Every NBO HID Kit is GUARANTEED FOR LIFE
Nathan @ NBO is offline   Reply With Quote
Old 05-03-2007, 09:33 PM   #4 (permalink)
If you did the work yourself, may I ask why you did'nt change the filter too. Seems like a small cost for a vehicle you paid tens of thousands of dollars for????
- Colgen Full front end bra
- Sherpak Go-7 luggage pack
- AVS sun roof windflector
Old 05-04-2007, 01:00 AM   #5 (permalink)
This sounds about right. There's a few ounces in the filter which won't drain out, you might easily have been a half qt low, and the rest might just be measurement error. Par for the course.
BTW, I think spec is 4.2 (w/filter) and I find it takes about 4.5 for me to get the oil to the top of the hash marks.
Old 05-04-2007, 08:46 AM   #6 (permalink)
You need to change the filter EVERY TIME you change the oil. It costs <$5 more and extends the job <10 minutes.
To answer your question, I can only speak in terms of when the filter is changed too. 5.1 qt in, and ~5+ qt out. I always use an empty windshield washer fluid jug to turn in the used oil and I always have more oil than the 1 gal jug can hold. As far as how much to put in, refer to the capacities as listed in the Owner's Manual. Hope this helps.
2004 Honda Pilot EX-L Sandstone
Running Boards | Trailer Hitch | Rear Splash Guards | Cargo Tray | Full Size Spare | Durabrand PVS 1960 DVD-in-a-bag | Thule 996 Expressway 4-Bike Rack | Covercraft UVS100 Sun Shade | All Season Mats | wwong's pads |
1997 Honda Odyssey | 1990 Honda Accord (Replaced by Pilot) | 1984 Honda Accord (Replaced by Odyssey)
Chess Pilot is offline   Reply With Quote
Old 05-05-2007, 06:13 AM   #7 (permalink)
I'm running the old style larger oil filter. My oil changes take a full 5 quarts.
