Hello- I need to change my serpentine belt- could anyone post the diagram from the service manual please? For anyone who has done it themselves, is it straightforward or anything to be careful of? I've done a couple on my lexus and it was easy-it had a self tightening tensioner- just turn the pulley to the left to loosen, release it and it self tightens- is the pilot the same? Thanks for time.
Just changed the belt this morning. It's straightforward but can test your patience so give yourself plenty of time.
Here were the steps I followed:[list=1][*]Move and hold the auto-tensioner toward the windshield with a 14mm box wrench.[*]Slide the belt from underneath the tensioner pulley.[*]Now there will be enough slack to remove the belt from around the alternator, AC compressor and crank pullies - I was able to pull the old belt from underneath around the splash guard area where the oil filter is.[*]Install the new belt over the crank and AC compressor pullies.[*]Move and hold the auto-tensioner as in step 1.[*]Slide the belt over the alternator pulley and then under neath the tensioner pulley - This is most difficult step as it will take some patience to manuever the belt around. If you have large hands, you will have some difficutly since space is tight. I found it helpful to release the alternator cable from the blue holding clip to make more room.[/list=1] Notes: Instead of the OEM belt I used the Gatorback Poly-V (4060470). Use an extra-long 14mm box wrench for better leverage on the auto-tensioner. My standard length wrench worked but it would have been easier with a longer one. Make sure the belt is lined up properly on the pullies.
Nope......I went with a Goodyear Gatorback Poly-V belt.
