Replacing Seats in 2006 LX - Honda Pilot - Honda Pilot Forums
Old 02-03-2007, 03:31 PM   #1 (permalink)
JeffT's Avatar
Default Replacing Seats in 2006 LX
I have a 2006 LX and have been able to buy the front and middle seats from an EX.
I swapped the middle row and front passenger seats quickly, everything lined up perfectly.
I need to know if I have to add a relay or anything else for the power drivers seat.
I know there is a fuse position for a 40 amp line to the seat and can run wire directly between the fuseblock and the seat, but want to make sure the system doesn;t require anything else.
Anyone have experience with this or a wiring diagram that shows this circuit?
JeffT is offline   Reply With Quote
Old 02-10-2007, 07:25 AM   #2 (permalink)
Superior Honda Tech
hondaman2's Avatar
it is a straight bolt on. only difference is 8 way power seat and seat heater if yours does not have it. i will need more info if you really want it to work.
Former USMC Sgt. 10 years
Old 02-11-2007, 01:10 AM   #3 (permalink)
JeffT's Avatar
I understand that it is a straight bolt on, just like the other seats I already swapped. My question has to do with the power connection.
Can I just run 12v from the fuse block to the seat and connect it or do I need a relay in the circuit?
