The thermostat is a spring loaded looking device that opens and closes, all mechanical, nothing electronic. It fails in one of two ways, (1) It sticks open or (2) it sticks closed.
If it sticks open, option 1 the usually failure I believe, the vehicle will warm up very slowly. Once warmed up it will run fine but until then the heater won't put out much heat and the motor will not operate efficiently. (In the old days with carburetors the choke would be open and the vehicle would consume more gas. Not sure what happens today). Main symptom - slow to warm up in cold weather. Solution - Replace thermostat. If it sticks in the closed position, not as common, the motor will run hot and can overheat causing engine damage. Sticking completely closed effective seals the radiator off from the engine. Symptoms - Engine rapidly warms up and runs hotter than normal. Solution - Replace thermostat. Used to be simple to do, main problem would be bolts to thermostat being difficult to remove. Would be surprised to hear of an 03 with a bad thermostat but not impossible. Keep us informed.
Its rare very rare for thermostats to fail and its also very rare for the water temperature sensor to fail.
The latter might also cause poor starting especially in cold weather assuming the ecu checks the water temp to decide how much extra fuel/revs are needed during initial start up |
![]() Join Date: Jan 2007
My coolant temp needle sits right below the temperature symbol on the gauge. Does that mean the thermostat needs to be changed? IF So, where is it in the Pilot and any trick to changing it? (I've changed it on other vehicles before)
Thx in advance! |
Here's what the manual says about where the needle shgould be.
While we are discussing this, I think the picture below shows the thermostat-housing, but what's the removal procedure?
There appears to be 2-3 bolts holding it, only the one on top is visible. Thanks again. |
#9 (permalink) | |
![]() ![]() ![]() ![]() ![]() Join Date: Sep 2003
Larry
2010 CR-V Urban Titanium Metallic EX-L, Nuvi 2460LMT GPS, also '07 Accord EX-L. Former proud 7 year owner of 2003 Pilot EX-L. |
A typical recommendation is to replace the thermostat when you change out the water pump. This replacment, in turn, is typically done when you change out the timing belt (at 60K on the Pilot, if I recall correctly).
If you do annual (or even bi-annual) coolant changes, you're very unlikely to have thermostat issues for the life of the part. I wouldn't put a whole lot of credence into small variances in where the temp gauge happens to rest at normal operating temperatures. Some makes calibrate it to read 1/2 scale or a little more, others 1/3 scale or even a little less. Even on the same make, there is some variance - these aren't precision instruments. - Mark |
#11 (permalink) | |
#13 (permalink) | |
You are right about replacing both the water pump and t-stat during this service. Especially the water pump. |
