What is the retighten torque for the fill and drain bolts when you change the VTM Fluid, same as the Tranny 33 and 36 lb ft?
Changed both today, but would like to torque them to spec. Thanks. |
#2 (permalink) | |
Current Hondas: <FONT COLOR="#000000"><B>2006 Honda Pilot 4WD EX-LN</B></FONT> <FONT COLOR="#999999"><B>2004 Honda S2000</B></FONT> |
![]() ![]() Join Date: Jan 2006
The torque for both fill and drain holes for the VTM are 35 lbf-ft.
2.79 US Quarts of VTM Fluid. Page 15-44 of the service manual. the CRV Refuge
2006 Pilot EX 4WD, Born in Bama, |
Superior Honda Tech
due to the crush washer on the plug it will always go past the line when you re-tighten it unless you use a new crush washer just like the one you change when you do your engine oil.
crush washers are aluminum gaskets and are used on: engine oil drain plug trans oil drain plug trans oil fill plug VTM drain plug VTM fill plug transfer case drain plug(front diff) transfer case fill plug(front diff) engine block coolant drain plug misc trans bolts misc sensors
ASE master certified Honda Technician Former USMC Sgt. 10 years Army National Guard Sgt. 2 years |
