LinkBack | Thread Tools |
Rating:
![]() ![]() ![]() ![]() Join Date: Nov 2006
I was going on a long trip for the Holidays and checked under the hood and noticed like many others who have newly purchased Pilots that the coolant reservoir was about 1/2 and inch to an inch below the min. line. Being it was Christmas Eve and the Honda dealership was closed at the time, I was not able to go to them top it off for me, being it was new and they didn't bother to fill up completely when they did the pre delivery inspection.
So went to Autozone and topped off the coolant with some of their new formula extended protection Prestone, the Honda manual says that Honda coolant is recommended, but if not using Honda coolant to use a non-silicate based coolant that is safe for aluminum engines. Prestone bottle reads safe for all types of cars, can mix with any color and safe for aluminum engines. At most I used maybe a 2 cups worth of Prestone. Will this cause me any problems. or do I need to go to the dealer to have them flush out my coolant system and replace with their coolant. By the way the Honda coolant is blue and the Prestone is green. Lesson to be learned here, at least open the hood and check fluids before driving off the lot. I really don't want to spend that kind of money hopefully. Any input would be appreciated
2007 EX-L Pilot 4WD Saddle interior Dark Cherry Pearl and 2007 EX-L 4WD w/ NAV Saddle interior Formal Black |
#3 (permalink) | |
I would probably change it in 3 to 5 years.
Drill Here, Drill Now
You're fine, don't worry about it at all, but you probably should have added only water.
thanks guys, that makes me not as worried about it. What I will do is probably what N_Jay said and to change it in a couple of years if not sooner.
I went ahead and bought a gallon of the HOnda stuff this morning , just in case things like this come up again. If I didn't know any better when things come up like this ,it kind of made me think Honda has a monopoly on the coolant market with their vehicles.
Next time, try one of these:
[http://www.peakantifreeze.com/peak_g...time_5050.html] [http://www.peakantifreeze.com/peak_global_lifetime.html] |
Look at their requirements for "long-Life" use. Apply the same to your Honda Long-Life antifreeze.
#9 (permalink) | |
Since proper mixing for long life antifreeze requires distilled water, premix is best. Using tap water in antifreeze is very bad for the engine.
#11 (permalink) | |
#13 (permalink) | |
#15 (permalink) |
![]() Join Date: Dec 2004
Not sure if this applies to our Pilots but my 99 Accord's Owner's Manual indicates to use non-silicate antifreeze. The label should indicate if it contains silicates. Wife has the Pilot so I'm not sure what the Pilot OM specifies. Now I'm curious
05 Pilot EX-L, Taffeta White Nifty Catch-All Mats (Charcoal), Donnelly Day/Night/Temp/Compass Mirror, Unswitched 12v power to armrest, WWong Pads, Ratso Grill Accents, Cross Bars, Full Size Spare on LX rim, OSRAM Silver Stars |
