I usually change my own oil in my 2005 Pilot. The first oil change I was surprised to find that Honda was using a 11/16 SAE drain plug as opposed to a metric one. I couldn't find time to do the 4th OC so I took it to the Firestone store in the neighborhood. The next time I change the oil I found the head of the drain plug all but destroyed from the butcher mechanic attemping to force a 17MM wrench on to the 11/16 drain plug. After getting it out I take it back to Firestone to show what the mechanic had done to my plug. Long story short I lost the battle, they insisted it was 17MM and at the time I couldn't prove otherwise. I get the plug back home and being a machinest type I measure the plug with a micrometer, it measures .6875, within a thousandth or 2, I don't tremember. Exactly the dimensions for 11/16, my plug is without a doubt 11/16. My question is, is this normal or do I have an odd ball plug? I should pop for a new one because this one is chewed up pretty badly. Any comments on drain plug size? What size is yours?
Gene |
17mm here. I just assumed everything on the Pilot is metric. I can't see Honda having some metric and some SAE fittings
17mm also. And is the plug you have on there 11/16ths head and metric threads? This wouldn't make any sense.
Something is fishy. My guess is that your car had the drain plug replaced with a non-standard part at some point before you got it. - Mark |
I know what you guys are saying but I bought the car in the wrapper so to speak, they had to put it through delivery prep. If the plug was not installed I would take a picture of it with the wrench on it. I'm dead sure of my findings, it measures 11/16 across the flats and my 30 year old 11/16 Craftsman wrench fits to perfection. The 17mm makes and did make a mess out of the plug. I don't get it either, it doesn't make sense, when I did the first oil change, the first wrench I grabbed was the 15MM and 17MM and they didn't fit after working at it for a couple minutes. After fiddling I finally tried SAE wrenches and struck gold. I am very competent at threading and making my own parts on an engine lathe from hex stock, it's not like it's something I'm not familiar with. I've been changing oil for a long time. So everyone's plug is 17MM is what I am reading here.
Gene |
I went down and checked mine (it is out because of my fumoto drain valve).
It is indeed a 17 mm. Something is bizarre about yours being different............. I also enthusiastically endorse Fumoto drain valves. I have it on both Hondas, going on the Miata next oil change. They make life so easy. Now just for that pesky Miata filter! And I thought the Pilot's was messy!
ncelk ------- 2009 Toyota Camry Hybrid 2002 Mazda Miata SE 2006 Acura MDX Touring |
