Interesting Maintenance Minder message - Honda Pilot - Honda Pilot Forums
Old 09-26-2006, 10:51 AM   #1 (permalink)
Default Interesting Maintenance Minder message
Well, it's coming up on time for the second oil change in my '06. The Maintenance Minder came on with the service code "A16."
  • "A" is the code for the oil change.
  • "1" is the code to rotate the tires and check the inflated pressure.
  • "6" is the code to change the VTM-4 fluid.
The interesting part is that I have a 2-WD Pilot! You'd think that the system would know that and not tell me to change that fluid!
It makes me wonder how many dishonest dealers would charge for that service (changing the VTM-4 fluid) even though they did nothing!
Oh, well. It's a nit, but I thought it was worth noting here.
Later,
Larry.
DiskStroyer: http://www.diskstroyer.com
larrys is offline   Reply With Quote
Old 09-26-2006, 01:34 PM   #2 (permalink)
mmmmark's Avatar
How funny. I'll have to keep an eye out for this and see if my 2wd gives me the same thing.
mmmmark is online now   Reply With Quote
Old 09-26-2006, 10:27 PM   #3 (permalink)
ctobio's Avatar
Perhaps on the 2WD, it means you need to replenish the blinker fluid.
That said... I guess the module handling the maintenance minder is the same across all versions. Good to know.
Constantino Tobio
Vehicles in the driveway:
'73 VW Fastback, Marina Blue
'94 John Deere LX176
Old 09-27-2006, 03:06 AM   #4 (permalink)
ictvuser's Avatar
Default Re: Interesting Maintenance Minder message
I wonder if this means the Maintenance Minder for the VTM-4 is just mileage based and does not factor in light or heavy usage?
Honda Pilot 2004 EX-L SBP
Old 09-27-2006, 08:39 AM   #5 (permalink)
Phi
Send a message via AIM to Phi
Default Re: Re: Interesting Maintenance Minder message
Unfortunately, based on what was said above, it looks to be the case.
2006 Honda Pilot EX-L w/ NAVI
2000 Acura 3.2TL w/ NAVI
Phi is offline   Reply With Quote
Old 09-27-2006, 09:14 AM   #6 (permalink)
Default Re: Re: Re: Interesting Maintenance Minder message
Or it could use the engine usage factors for everything?
Old 09-27-2006, 03:13 PM   #7 (permalink)
ctobio's Avatar
Default Re: Re: Re: Re: Interesting Maintenance Minder message
That would be my guess. Originally I would have thought it counted how often and at what rate it was locking the VTM clutchpacks. I still don't think it's purely mileage dependent for the VTM. Perhaps the maintenance minder only interfaces with the dashboard and ECM, and no other systems.
Constantino Tobio
Old 10-23-2006, 12:42 PM   #8 (permalink)
I have a 03 Pilot and recently took it to DEQ for tag renewals. It came back with the OBD Sensor status of "UnReady". They were Catalyst, 02 Sensor, and Evaporative. The dealer said that the drive cycles must be reset and the only way to do that is to just drive it. I had a new battery put in over 6 months ago, so I'm not sure why these haven't reset? Has anyone experienced a similar issue and if so how were you able to get the issue resolved?
dkerke is offline   Reply With Quote
Old 10-23-2006, 07:37 PM   #9 (permalink)
mmmmark's Avatar
Usually just a few restarts will reset the codes. Do you know anyone with a scan tool of any sort? They can reset them for you in a hurry!
