Help: Licence plate light - Honda Pilot - Honda Pilot Forums
Old 08-16-2006, 05:59 PM   #1 (permalink)
Default Help: Licence plate light
This is probably a dumb queston but how to do you remove the rear licence plate light cover? To change the bulb. I looked at it and theres an arrow that reads remove. But I gave it some force but nothing. I wanted to check first before causing any damage. Ive also tried looking in the manual and used the search button.
Blazin036 is offline   Reply With Quote
Old 08-16-2006, 06:39 PM   #2 (permalink)
Just use a flat head screwdriver to remove the lens cover. It might give you a hard time, but it will come off. Use it to loosen it and use your fingers to take the whole thing off.
Old 08-16-2006, 07:04 PM   #3 (permalink)
do i push to the passanger side or pry down?
Old 08-17-2006, 02:36 AM   #4 (permalink)
Pry down on it and it should work. I did it not too long ago when I replace the halogen bulbs with LEDs.
