Transmission dipstick and fluid volume - Honda Pilot - Honda Pilot Forums
Old 08-09-2006, 08:39 PM   #1 (permalink)
Default Transmission dipstick and fluid volume
Anyone know how much transmission fluid you need to add if the level is at the bottom mark? This is for an '03 (not sure if that matters). Just seeing if anyone else has determined this before I go and do the trial and error thing...
Thanks,
Chris
cwdehart is offline   Reply With Quote
Old 08-09-2006, 09:42 PM   #2 (permalink)
pilotjorge's Avatar
You will need half a quart more or less.
The right level should be in between the upper and lower marks.
I'd fill it up slowly and recheck the dipstick till it gets to the right level.
Here's a link for more info.
Transmission Fluid
pilotjorge is offline   Reply With Quote
Old 08-12-2006, 03:57 PM   #3 (permalink)
My 04 came that way from the factory, it took a quarter of a quart to move the level to the full line.
Old 08-12-2006, 10:39 PM   #4 (permalink)
I just changed my tranny fluid today.
I did not fill it up to the full line.
The manual states that the right level should be IN BETWEEN the bottom line and the full line.
And it takes almost a quart from the bottom line to fill it up to the right level.
I have an 04' Pilot myself.
helpless is offline   Reply With Quote
Old 08-13-2006, 12:51 PM   #5 (permalink)
I don't think there is any need to make sure it's at halfway or anything. Any level between the two lines is acceptable and it probably makes no difference exactly where it lies between.
Old 08-13-2006, 02:18 PM   #6 (permalink)
Transmission Fluid Level
2004 Honda Pilot EX-L: Nighthawk Black Pearl: Date Built: July 26, 2004/4:57am
Date Acquired: Sept. 06, 2004.
Aru4mie is offline   Reply With Quote
Old 02-14-2008, 02:27 PM   #7 (permalink)
dirk877's Avatar
Lightbulb
Excellent Post...
The picture clears everything up for people...
2005 Honda Pilot EX
148,362 Miles
dirk877 is offline   Reply With Quote
