LinkBack | Thread Tools |
Rating:
#106 (permalink) | |
2007 Pilot LX 2004 Suzuki V-Strom |
#107 (permalink) |
changing the diff fluid is easier than what i expect. I do it all the time for my wrx but the 1/2 bolt that i have to get off on that car is hard as hell.
thanks for everyone's input. |
#108 (permalink) | |
#109 (permalink) |
![]() Join Date: Dec 2007
was $48 at the dealer we bought the vehicle from and $31 at the one closer to where I work (normally $40 but they quoted me $31).
Man those plugs were in tight, next time I'll probably drop the spare so I can use a longer extension, too much going on in that area. Filled it up, took it for a little drive, checked the level and it took another 3 or 4 pumps (~1/4 qt) before it started weeping out again. Had fun getting my tq wrench around everything down there too (the lower coil seat was getting in the way). Overall, better than paying the dealer $80 to do it. I'll keep my $40 for 45 min of work (most of which was waiting for the fluid to finish draining). If it lets me go 3 oil changes next time, I wont have to do this again for over a year.
'05 Nissan Frontier - 6-spd crew cab, 2" lift, 285/75-16 M/T's (mine) '06 Accord - 4-dr, 4-cyl auto (hers)(gone) '08 Pilot AWD (hers) |
#110 (permalink) |
![]() Join Date: Apr 2006
Does anyone know what the torque specs are for the drain & fill bolts for the VTM? I've searched this thread and couldn't find them anywhere.
I have a 2008 Pilot. Thanks in advance.
2008 Pilot EX-L, Nimbus Gray OEM Running boards, Nav System, XM Radio, USA Spec iPod adapter, Philips 4300k HIDs, Weathertech Floor Liner, wwong's console pads |
#111 (permalink) | |
#112 (permalink) | |
#113 (permalink) |
In the 2003 Manual, the specs are 35 lb.ft for both the filler and the drain plugs.
#114 (permalink) |
What about the drain/fill plugs in front of the driveshaft? They appear to have the same 3/8" plugs as in the rear. Does it require a drain/fill with VTM-4? These are not the drain/fill plugs for the auto trans.
Thanks. |
#115 (permalink) |
Yeah, the forst time i did the fluid change, it was $22/gal. Today the it was $33. I thought we were in a recession?
'05 EX-L '01 Altima SE '67 Corvette Conv. |
#116 (permalink) | |
That's the transfer case. Takes about 1/2 quart of gear oil. This is on an MDX but it's the same thing: http://www.mdxers.org/forums/showthr...threadid=23082 Get a pump like this (Advance Auto has them) and it's a 20 minute job. Mobil 1 75W-90 works great. 20mm washers for both drain and fill. [
#117 (permalink) | |
It's barely mentioned in the Honda owners manual. Only states the fluid should be changed in the transfer case under sub item 3 of the maintenance minder... No mention of the type of fluid or capacity. I'll use the pump I have already. It worked well for the differential and transmission fluid change already. Do you have a rough idea as to the mileage I should reach for the transfer case fluid change? Not sure when "sub item 3" is going to pop up on the instrument cluster. Thanks again.
2006 Pilot EX-L : Roof rack, hitch, side steps, bug deflector, mud guards, fender flare kit, bull bar, driving lights, cargo tray, Akebono pads + Brembo blanks, trans cooler 2006 Accord EX-L Sedan V6MT : Mud guards, 20mm TL rear sway bar, trunk tray, Akebono pads + Brembo blanks 2006 CRF250R 1985 TRX125 1987 Mustang GT |
#118 (permalink) |
I don't know what Honda would recommend, but I think it is good for quite a while. Probably 50K miles would be a safe number. I don't think mine had ever been done before and I changed it at 74K miles and it still looked and smelled new. Since most dealers don't even admit that it exists and it would be a great money maker for them, I doubt it is something that needs serviced very often. It's easy to do so I will probably just change it two times (drive a month or two in between) to sort of flush it out and then maybe every couple years.
I would not reuse the same pump for the rear diff and the transfer case. I have read that even a little bit of contamination of the VTM4 fluid can lead to chattering in the rear diff. Sounds minuscule, but several people have posted reusing a gear oil pump made their diff act up, they flushed with clean VTM4 and the problem went away. |
#119 (permalink) | |
#120 (permalink) | |
Changed my VTM fluid yesterday according to your excellent pictures and explanations. It took an extension handle on the ratchet to break the drain and fill screws loose. They didn't "EASE" loose, they POPPED loose. Also checked the air in the spare. It had 15 PSI, so got it back up to the recommemded 60#. Bought a pump from Advanced Auto. Looks like the one "Carguy07" shows in above post but a different brand and solid black.. It seriously took near 300 pumps per quart of VTM-4. That is no exageration. Took nearly an hour to fill the case. . This pump actually screwed onto the gallon jug and reach to within 1/2 inch of the bottom. It did the job, but painfully slow. ![]() Looking for another pump for the next change. The type you show is readily available and I have one, but have been using it for kerosene, so wouldn't want to use it with VTM-4. Mine works fine for thin kerosene but don't know how it would do for the thicker VTM-4. Anyone with any suggestions would be much appreciacte. Thanks, Kip |
