LinkBack | Thread Tools |
Rating:
#77 (permalink) | |
Good time to clean out the grunge on the spare as well.
#78 (permalink) | |
The wheel jack points are just behind the front wheel well, and just in front of the back wheel well. You can see there is a kind of a bend and thickening of the sheet metal. I have also used the "fake" I beam where is is flat. I think near the rear it tends to curve, so I have not used it there. If you get under and look you will see what I mean. I just used them on weekend to lift the Pilot up and take off the snow tires. Good luck Here's a link where it lifted at a shop, gives you some ideas 2004 Pilot Underside
#79 (permalink) | |
2007 EX-L/RES X-bars,Splash, Steps, Tow package WWong's Pad Set Fog light lens protectors Weathertech Mats Desert Rock Metallic 2002 Jetta TDI |
#80 (permalink) |
Wook #17
Knocked out my first VTM fluid change yesterday.
Thanks to HP.org and its members for the great DIY instructions. Two small issues I had: 1) Breaking free the bolts. This was solved with a cheater bar. 2) The pump I bought, is a "grease gun" style pump/suction apparatus. The chamber only holds 16oz, so it took several fillings to refill the fluid. That being said, when I spoke to the Honda parts guy, he advised that at his shop they only remove one of the plugs, then suck all the fluid out, and just pump the refill back in. One last thing, my 2005 Pilot, had crush washers on each plug, which the parts guy didnt know. He thought there was only one on the drain. I replaced both of course.
"This is going to be a very expensive war, and Victory is not guaranteed -- for anyone, and certainly not for anyone as baffled as George W. Bush. All he knows is that his father started the war a long time ago, and that he, the goofy child-President, has been chosen by Fate and the global Oil industry to finish it Now." Dr. Gonzo |
#81 (permalink) |
Hey all,
Another good fill method is to have an inexpensive tube which screws right on to the jug. You can get these at Advance Auto or other places. They work on quarts too. Just put on like you would a cap. The part is two-piece - one is the clear tube and one is the "cap" which has has a black and a red section. They turn and allow you to shut off flow. So, you can turn the whole jug upside down with no fluid release until you open it. You can then squeeze out all the fluid you need. I find it better to pour off some into another container, but you dont have to. I usually have a part of a jug and just guesstimate what I will need. And yes, it is about 3 quarts. Keep filling until it drools out. Obviously, best to fill slowly, especially toward the end. On the washer, as I posted in another thread about Trans fluid change on an 03, turning them over works great. If you get confused on which way, just feel for a groove on the inner part of the washer. If you cant feel one, then it doesnt matter. The whole reason to turn it is to have a flat side against the case and allow the bolt to flatten the washer on its side. Also, the rear dif and trans drain plugs take the same washer. Buy a few and oil ones next time you order from wherever you get parts - like Majestic Honda, Bill Kay, H and A, etc. Rear dif fluid recycles just like ATF and motor oil and it doesnt matter if you mix them for recycling. |
#82 (permalink) |
![]() Join Date: Jun 2007
Took care of this today and it was pretty simple. The hardest part was getting the bolts off (used breaker bar + pipe). Besides that, it just took a little time to pump the fluid back into the rear diff...very easy DIY job though and definitely saved me some money since I just got reemed from a dealer brake job
-SC 2003 Berlina Black S2000 2003 Nighthawk Black Pilot EX |
#83 (permalink) |
Those things have a tendency to seize - the plugs and especially the caps. I have found that a good torque wrench works well because of the length. The key is to give it a rocking or a snap - this works sort of like an impact wrench would and it breaks it loose.
#84 (permalink) | |
'04 EX-L with RES, purchased used 6-7-07 |
#85 (permalink) |
Yeah. You are right about the torque wrench or any other ratcheting tool. It does aid with the leverage because of the length, and the rocking or snapping applies even with a breaker bar or whatever you use.
#86 (permalink) | |
andy
#87 (permalink) | |
#88 (permalink) | |
Made it a much easier task! When i did it on the '04, it had the small spare and you had enough room to do things without removing the tire - but the full sized spare just took up toooo much room.andy
#89 (permalink) |
Thanks for this great DIY. I am always looking for ways to keep from using the dealer.
Does anyone know the torgue for tightening the VTM-4 drain & fill bolts? The parts guys stated that the crushable washers are important to keep you from stripping out the threads.
#90 (permalink) |
I changed the VTM-4 fluid on our 2005 Pilot yesterday.
Fairly easy job, specially with the hand pump that I bought from schucks. I wanted to reply to this thread to make two points. 1- I did not need a ratchet extension. There was enough room behind the metal brace and in front of the differential fill bolt so I was able to use my ratchet by itself. So you may want to try that. 2- A few membere have mentioned that they actually had to top off the differntial after a refill and after driving a few miles. So I had to verify that. I opened the fill bolt and I too was able to add some more fluid to top it off. My guess (and it's just a guess) is that when we drain the fluid, there maybe some air pockets left after the refill. So when we drive a few miles that the differential relieves itself (sort of speak) of the air pocket and there is more room to top off. Thanks every one contibuting to this thread and to the entire forum. |
