vehicle weight - Honda Pilot - Honda Pilot Forums
Old 06-14-2006, 01:25 PM   #1 (permalink)
Default vehicle weight
Bought a two-ton hyraulic jack with jack stands to do the rotations. So tired of using the standard crank jack that comes with cars...takes forever.....I'm assuming our cars are less than 2 tons? Correct me if I'm wrong. Thanks....
mookie is offline   Reply With Quote
Old 06-14-2006, 01:54 PM   #2 (permalink)
Medic721's Avatar
2 Tons is 4000 lbs, the 2wd LX curb weight is 4264, the awd ex-l curb weight is 4524.
Thhat being said, a 2 ton jack is fine because you are lifting a piece of the car at a time, unless you plan on balancing your entire vehicle on the jack.
-Mike.
Old 06-14-2006, 01:58 PM   #3 (permalink)
gotcca. thanks. yeah, i plan on lifting each section at a time, and then putting a jack stand underneath as support/safety as i change out each tire, one at a time.
