Does anyone have any web sites that sells OEM Honda parts Cheap....I am looking to exchange the F/R Disc Rotors & Pads........any Info will be appreciated....
Try tirerack.com for the rotors. (Sorry Tim)
NO..........You are not Excused for your Ignorance......because you are Ignorant....FYI OEM stands for Orginal Equipment Manf....which could be made my numerous manufacturer for Honda....Genuine parts mean that they are made by Honda.....
'da Moderator
![]() ![]() ![]() ![]() ![]() Join Date: Jan 2004
![]() 1. Genuine Porsche® – Also referred to as "factory parts", Porsche has approved these parts as meeting the specifications as defined by factory engineers. This could mean a particular rotating balance specification (as in a clutch), a corrosion standard (as in a brake rotor), or a resistence tolerance (as in wire sets). 2. OEM Parts – OEM stands for Original Equipment Manufacturer. These parts are manufactured by the same company that supplies Porsche. However, the specifications are not required to be the same as Genuine Porsche Parts. For example, clutches sold by Sachs are not balanced to the Porsche specification, clutch master cylinders do not use the same quality seals, brake rotors lack the specified corrosion resistance and balance, and on ignition wire sets the resistence may be out of specification. 3. Aftermarket – Aftermarket parts are replacement parts that are not made by the original equipment manufacturer. DEVEK manufactures an “aftermarket” radiator - it is not OEM or Genuine Porsche. That is not to say the Genuine Honda parts are better the OEM and OEM parts are better than Aftermarket. In some cases, Honda parts are the best choice (e.g,. VTM fluid, tranny fluid, coolent), however, there are very good aftermarket alternatives for brakes, rotors, shocks, etc.
Honda Pilot 2004 EX-L SBP Rear backup sensors, 2004 Fender Flares, Chrome Bumper Garnish, Cross Bars Cargo Cover, Fog Lights, Cargo Bin, wwong's accessories |
#9 (permalink) | |
Of course when I'm a rude, obnoxious, AH, I make sure I am RIGHT first!
#11 (permalink) | |
'da Moderator
#12 (permalink) | |
#13 (permalink) | |
#14 (permalink) | |
There are times what I say is OPINION, and therefore may not be "right" (while still not being "wrong") I know you left leaning folk have trouble understanding how opinion differs from facts. Just like you have trouble understanding how something could be found to be wrong later, and still be the best choice at the time. (and lest not even get into the whole "lie" thing)
#15 (permalink) | |
'da Moderator
aka no spin zone
