While I am a few miles away from my 1st service, the dealer I purchased my Honda and the extended warranty through never mentioned anything re specific services...
I know from a Ford I used to own they had Service 1,2, 3, and 4 - and you would rotate through them ( again, ext. warranty ) - is this similar to Honda? |
#2 (permalink) | |
Don't mean to drift off from the last two posts...I have searched the topic, but need a direct answer.
I have had my pilot 5 months and have 4,500 miles on it. I really feel like it should be serviced at 3,000 like my old 4 cylinder 91 Accord. Why does the manual recommend 7,500 / 1year and the dealer keeps sending me letters telling me to come in for my 3,500 mile service. My parents own a 05 CRV (which has a smaller engine of course) and their manual also recommend a 7500 mile/6months service, but the dealer calls them as well. and that's a. What should I follow? I do have the Honda Care 7 year warranty on it, and I don't want to void it by not getting serviced regularly. Much Thanks
<b>2005 Steel Blue Pilot EX-L with Navigation</b><br> Foglights with lower trim · Black Side Steps ·Window Vent Shades · MudGuards |
And, any thoughts about that range of 5,000 to 7,500? That's a pretty big range. Should I do it on the lower end or higher end? Thanks! |
By the way, there are really only two service intervals for the Pilot... 3750 miles (severe) and 7500 miles (normal). Check your owner's manual to see which one applies to you.
As far as when to get the first oil change, check to see if you fall under the severe or normal maintenance schedule (check the owner's manual). If you are following the severe schedule, then go towards the lower end of the range. If you are following the normal schedule, then go towards the upper end.
Do I need to get my first service done now? If it's severe now, do I follow the normal schedule come spring to fall when it is mild or warm weather? Thanks in advance.
Honda Pilot EX-L 2005, Silver |
#9 (permalink) | |
I'm in WI, and I plan on following the "normal" schedule, which means first oil change at 7500 miles.
I use 5,000 miles as my oil change interval. It is easy to remember and it is between the severe and normal service. The old 3months or 3,000 miles is from the fifties and sixties when oil technology and filter technology were both light years from what is out there today. If you drive many short trips a month below 5 miles is freezing weather or 10 miles in warmer areas. Have many days over 90F (32C), excessive stop and go driving. Hope this help.
