I am looking for a hand pump to change the VTM fluid. anyone have a photo to show me what type of hand pump will work fine? OR what is the name of the hand pump? I suppose to buy it in the auto shop right?
Chrome side step, LoJack early warning system |
It is a standard transmission fluid pump.
They are usually about $5 Just ask, or walk down the isle at Walmart looking at the stuff near the transmission gear oil bottles.
http://www.partsamerica.com/ProductD...partnumber=816 |
That's the exact pump I used when I change my VTM-4 fluid. Works great! Attach that small enclosed tube to the bottom of the pump, so you can suck up the fluid on the bottom of the container.
Tip ... Remove the upper fill bolt first, before you remove the lower drain bolt. That way, if the upper bolt can't be removed (It's usually secured VERY tightly), you haven't drained the oil, and you can still operate the car. |
Thanks folks, with all the guidance up here, changing out the VTM-4 fluid was a snap. For $25.00 its a good idea at your first year, I have just under 12,000 miles and there was a fair amount of shavings on the magnetic drain bolt. If nothing else peace of mind is worth the money. Filler bolt is a bear, but did this cold, first thing in the am and hit both bolts with some lubricant to help me open them. Didnt take a ton of effort and they came right off. Definitely worth $50.00 of my time for a half hour job, and 25 minutes of it is just letting the fluid drain out!
both washers didnt have any imprints on them at all, I replaced them anyways, but would have been easy enough to just put them back on. |
The drain bolt on mine was tighter than the fill bolt. Was able to loosen the fill bolt normally (with a strong pull), but had to put the socket wrench on the drain bolt and pound on the handle with a piece of 2x4.
![]() Join Date: Jan 2004
For all those DIY-ers - did you need to jack up the front end to get to the bolts? Or is there enough clearance to crawl underneath the front end? Looking to do it for the first time this week. Thanks.
'03 Nighthawk Black Pearl EX-L<br> Webasto 744 Sunroof, PIAA 1700x Foglamps, Running Boards, Philips Cool Blues, Pioneer Receiver with 10 CD Changer, Auto Day/Night Mirror, Splash Guards, Cargo Tray, Crossbars, wwong's 3M stuff |
#11 (permalink) | |
.Seriously, there's plenty of ground clearance under the rear of the Pilot that you don't need to jack it up to get to the VTM. For the oil change, I jacked up the front-right and removed the wheel/tire. I've read that you can just turn the wheel all the way to the right, but I had to rotate the wheels anyway, and it'd be tough to get to the drain bolt with the wheel on.
#12 (permalink) | |
Oops, thanks for pointing that out (although I probably would've figured it out once I was under the car... "hey, where did the bolts go?")
USMC Pilot
Thanks for all the good information!!
2 gals of VTM-4 fluid and 2 sets of crush washers: $42.00 at the local dealer (figured I'd get it in advance to save me the trip next time) Got the hand pump at the Advance Auto Parts for $6.50 Total time to do - approx 30 mins start to finish. HP
2005 Honda Pilot EX-L SBP Auto day/night mirror, Tow package w/cargo carrier, OEM Cargo mat, Perfect-Fit air deflector, WWong's accessories, Nifty Catch-All front mats, OEM crossbars, Sirius Sportster 4 Replay, Garmin c530 Streetpilot, Bridgestone Alenza's |
How do you know when its full? Can you overfill it and do damage like the transmission?
#15 (permalink) | |
