How easy (or hard) is it to do change the transmission fluid? I searched the forum and didn't find any DIY postings. If anyone has done it and would be willing to type up the steps, I (and I'm sure others) would appreciate it.
Thanks in advance for any help.
2005 Honda Pilot EX-L (Desert Rock Metallic, side steps, crossbars, rear splash guards, wheel locks, towing package, full-size spare on EX rim) 2007 Honda Accord EX-L V6 sedan (Alabaster Silver Metallic, splash guards, wheel locks) |
Click on the link below, you'll need to scroll down a bit. Also, it should be in your owner's manual as well.
Transmission Fluid |
#3 (permalink) | |
Also, the owner's manual does not explain how to drain the ATF. It simply describes the process... no pictures or text to help locate the filler or drain bolt.
I bought 3 sizes of 3 ft. clear hose for next time. Here's the link I am talking about Good luck
Rip Tide Dude!
You need a 17mm socket and a long extension bar to remove the ATF filler bolt. It takes a lot of effort to loosen the filler bolt.
![]() ![]() ![]() Join Date: Aug 2004
Here's another link with some photos:
Transmission fluid changed Unlike the one pictured in this thread, the filler bolt on my '05 is silver and is stamped "ATF."
2005 Pilot EXL (Black/Saddle) - OEM Foglights, OEM Hitch, OEM Woodgrain Kit, OEM Splash Guards, OEM Full Nose Mask, Wong's Pads, Weathertech Mats, Pilot SS Exhaust Tips, Delphi SkyFi XM Radio |
I CHANGED MY TRANS FLUID THIS WEEKEND. THE PARTS SALESMAN SAYS THREE QUARTS WOULD DO. WHEN I DRAINED IT ABOUT 4 QUARTS CAME OUT. SATURDAY AFTERNOON, ABOUT 45 MILES FROM THE HONDA SHOP DID NOT HELP THE SITUATION. I THINK THAT THE CAR WAS ON AN ANGLE WHEN I DRAINED IT WHICH ALLOWED FOR MORE TO COME OUT. I DROVE IT ABOUT 3/4 QT LOW MONDAY MORNING TO THE SHOP AND TOPPED OFF THE FLUID. IT SEEMS THE TRANS HOLDS ABOUT SEVEN QUARTS BUT WHEN DRAIN PROPERLY ONLY A PART OF IT COMES OUT, SO REPEATED DRAIN AND FILLS ARE REQUIRED TO CHANGE IT ALL.
I FOUND A PIECE OF RUBBER HOSE ( 8 INCH) THAT FIT TIGHTLY OVER THE DIP STICK TUBE AND ONTO A SMALL FUNNEL WHICH MADE REFILLING IT EASY. BUNKIEPILOT |
#9 (permalink) | |
Feedback Score: 1 reviews
Very easy to do... don't pay someone else to do it. First of all, the vehicle is so high off the ground that you don't have to jack it up or anything. Just use a 17mm socket with a LOONGGG extension, maybe 18" or so, and use a 1/2 drive or breaker bar. The picture in the link by e2e shows the filler bolt which has white paint or something on it. As with any drain/fill procedure on an automobile, always, always, always loosen the fill plug first! If you drain first and have trouble loosening the fill plug, whoops!!!! Also, don't overtighten the fill plug between fill/drain/fill cycles. Just a little over hand tight is enough. I think the difference between the aluminum housing and the plug metal (whatever it is) almost causes a galling (seizing) effect. During both of my ATF changes, the plug seems to tighten itself when I did my drain, fill, drive a couple of miles, then drain again cycles. Not really a problem, just aggravating to have to muscle the plug out 3 more times before the process is completed. Be prepared to go through about 12 or 13 quarts of fluid to get a full replacement of fluid. I guess the tranny holds 10 or more quarts of fluid and only 3.5 quarts will come out with a single drain, leaving a WHOLE bunch of fluid left in the tranny and torque converter. I've found that the fluid that comes out after about 15k miles of use is still the same color and smell as when I put it in. I know it does get contaminated, so can't go by the color/smell to justify longer intervals. Plus, I tow a boat and a camper down in South Texas where the heat is just awful about 7 months out of the year, stressing out the fluid enough in my mind to warrant the frequent changes. Good luck, and go by Walmart or any parts store and buy one of those 2 foot long funnels to get down to that filler bolt. The opening is about as big around as a quarter, so just about any funnel neck will fit in the hold.
I found the DIY transmission fluid change instructions made by fellow forum member pilotjoe to be very helpful when I did my own. I believe its on pages 4 and 5 of this related thread:
Transmission Fluid
2004 Honda Pilot EX-L 2003 MDX Touring |
