What happens if you let VTM-4 go? - Honda Pilot - Honda Pilot Forums
Old 10-13-2005, 09:53 PM   #1 (permalink)
Default What happens if you let VTM-4 go?
Curiosity question, really. I've owned a lot of 4x4's over the years, and I've never had one with such a short interval of change for the rear diff that the Pilot has.
So what happens if you don't change it often enough? Does the rear diff wear out, or does it simply stop working?
Don
DN325Ci is offline   Reply With Quote
Old 10-14-2005, 06:05 AM   #2 (permalink)
jl_ss's Avatar
Default Re: What happens if you let VTM-4 go?
Don
It will potentially wear out a lot faster and then you have voided the warranty by not following the required service interval and will have to pay a lot more money to fix it.
Old 10-14-2005, 06:06 AM   #3 (permalink)
Sunday Rider's Avatar
Don
You will wear out the clutch packs that make the VTM4 work. This material seems to break down easily, and I think that is why you need to change it frequently. You must use the Honda stuff because it has special additives. I had a local shop use the hand pump from his automatic transmission fluid, and that little bit left in the pump, caused the back to grind, I had to have him change it again 2 weeks later. This time I had him flush the pump out with the fluid left from the last change, and use a brand new Honda VTM4.
So from my experience, I wouldn't neglect this area.
Sunday Rider
Honda ST1100 '97
Honda CB900C '82 sold
Honda CM400E '80
Old 10-21-2005, 03:56 PM   #4 (permalink)
VTM-4 fluid is easy to replace. Just drop the spare tire and the rear-end drain & fill plugs are readily accessible. No reason to skip this maintenance.
Gliderpilot is offline   Reply With Quote
Old 10-21-2005, 07:50 PM   #5 (permalink)
tangotango99's Avatar
Don
= A Penny wise a Pound foolish
Old 10-21-2005, 11:11 PM   #6 (permalink)
Completely agree. I've done it and it's very easy.
VTM-4 fluid seems relatively thin by comparison. My prior 4x4s used much heavier weight stuff.
Don
Old 10-22-2005, 08:54 AM   #7 (permalink)
No need to drop the spare tire. I've changed mine twice, it's literally a 15 minute deal. Make sure you get a $5 pump that will screw onto a gallon jug. 2 new crush washers + 1 Gallon jug of rear diff fluid + hand pump < $25, and you'll have about a quart of fluid leftover for the next change.
Old 10-24-2005, 01:36 PM   #8 (permalink)
cwa107's Avatar
Don
I think the cause for confusion here is that you keep referring to the VTM-4 as a differential. It is not a differential, it is a clutch pack. That said, the lubrication needs are a little different from what you may have experienced in other 4x4s (as you've noted here).
Old 10-24-2005, 02:01 PM   #9 (permalink)
Is the VTM-4 fluid commercially available under another trade name, or do I have to get it from the dealer only?
Mark in MA
markjmay is offline   Reply With Quote
Old 10-24-2005, 02:02 PM   #10 (permalink)
Good thing I checked this thread. I have 20K on my '04 EX. I need an oil change and tire rotation so I'm scheduled for two weeks from now. Noticed the manual said 15K and 30K are the first milestones for VTM-4 fluid change. I would have never thought that a new car would need something so major (though relatively simple to change apparently) done on it. In addition to the VTM-4 ($79 bucks or so) I'm getting the oil changed, tires rotated, multi-point inspection, yada yada for $99. Anything else I should have done? When would you say (in the future that is) I have to bring it in for something other than an oil change. 30K? I used to do my own fluid changes but after a while my time became more precious than what it costs to have someone do it.
coeng73 is offline   Reply With Quote
Old 10-24-2005, 02:03 PM   #11 (permalink)
cwa107's Avatar
Mark in MA
Unfortunately, no - you have to get it from the dealer.
Old 10-24-2005, 04:02 PM   #12 (permalink)
prijo's Avatar
Dealer is charging you $79 for VTM4? Consider negotiating this price with them. THe Honda Dealer in Columbus, OH charges $39 (another poster on this forum posted this price) which is fair for $20 in material and 15 minutes to perform.
2005 Pilot
Sage Brush Pearl
UNHAPPY about 70MPH VIBRATION
prijo is offline   Reply With Quote
Old 10-24-2005, 08:00 PM   #13 (permalink)
That's one of the reasons why I do my own maint, I refuse to wait while the dealer does something I could do in the same amount of time. Or worse yet, be inconvenienced by dropping off the car and coming back later.
Old 10-24-2005, 09:48 PM   #14 (permalink)
I hardly use my VTM-4. Maybe just a couple of times in the winter snow, but that's it.
Most of the time, the Pilot is in front-wheel drive mode. So, I don't see why we need to change the VTM fluid at all.... Am I wrong?
OverDrive is offline   Reply With Quote
Old 10-24-2005, 09:53 PM   #15 (permalink)
cwa107's Avatar
Default Re: Re: What happens if you let VTM-4 go?
Yup. Every time you accelerate, the VTM-4 engages. VTM-4 is not completely reactive (i.e. only turns on when your wheels slip), there's always some torque being sent to the rear wheels. This is why when you pull away from an intersection in the rain, the front tires don't even start to slip.
Now, if you do start to slip, that amount of torque is increased all the way up to 55%, but even when you don't slip, there's always at least a little bit of torque sent.
