2003 Pilot EX - Honda Pilot - Honda Pilot Forums
Old 09-01-2005, 11:42 PM   #1 (permalink)
Default 2003 Pilot EX
Long time reader; first time poster. My wifes pilot had 55k miles and being a little old school I can't believe spark plugs last 100k. I decided to change them and although the process was tedious and time consuming I think it was worth it. For whatever reason the spark plugs I replaced have a burnt orange coloring at the base of the ceramic. I am not sure if this is horribly bad, but I know it is not ideal. Anyway I replaced them with Bosch Platinum2 and my acceleration and power seem to have improved. I did replace the air filter which could be partially responsible, but I think changing the spark plugs is worth the effort and cost (3.99 x 6 = 23.94 + tax).
Instructions.
1. Remove the plastic engine cover bolts (10 mm)
2. Remove the plastic cover in front of the radiator. This exposes the three front spark plugs.
4. You then need a 6 mm hex wrench to remove the bolt that attaches the spark plug wire to the valve cover.
5. Remove the spark plug wire. Remove the spark plug wire using a 5/8 inch spark plug socket. These two are somewhat difficult as there is very little room to manuever a ratchet and socket, but it is possible.
Of course you have to replace the back three as well which aren't really easy to do, but again possible with a little patience and fortitude.
Not the best instructions, but if you are mechanically inclined you should be able to do it.
I will post pictures of the plugs I removed to demonstrate the discoloring.
Stephen
smswartz is offline   Reply With Quote
Old 09-02-2005, 08:38 PM   #2 (permalink)
madvtaky0!
graveltravel's Avatar
well i hate to tell ya , but platinum plugs are a waiste of $$$. you should have bought some ngk v-powers. alot of people dont know that most of the platinum burns off the plug at around 1000 miles. but on the otherhand, thanks for the write up!
praise the lowered
graveltravel is offline   Reply With Quote
