Shocks & Struts - Honda Pilot - Honda Pilot Forums
Old 08-16-2005, 12:04 AM   #1 (permalink)
sageo's Avatar
Question Shocks & Struts
I've got a 2004 Pilot with 30k miles. Just replaced the lack of Integrity's with Michellin CTs, and suspect I'll need the front rotors turned and pads replaced within the next 5k miles.
What about shocks and struts? I've not seen any threads on this topic. Does anyone know if any aftermarket products are better than OEM?
Peace out
sageo is offline   Reply With Quote
Old 08-25-2005, 05:05 PM   #2 (permalink)
I was actually wondering the same thing... I've hit 36k miles on my '03 EX and recently installed the CTs. I've had pretty good results with Bilstein, Koni, and Tokico but wasn't sure of the "best" setup for a stock Pilot?
Thanks!
Roger
2003 EX-L RES
Nighthawk Black Pearl
rogermoises is offline   Reply With Quote
Old 08-25-2005, 05:24 PM   #3 (permalink)
I recommend against turning the rotors. They've already shown a tendency to warp, and removing matierial is only going to make it worse. You'll have better results with new rotors.
Old: 2005 EX-L NAV
Old 08-26-2005, 11:48 AM   #4 (permalink)
Rapid Rob's Avatar
Not really. We usually take off .2 to .4mm of each rotor. The first turn of a rotor won't take that much off. You are correct about having more mass for a heat sink, though.
The thing is new rotors aren't seasoned with heat cycles, and can warp just as easy. Rotors are warping for several reasons, not just too much heat.
Old 08-26-2005, 11:51 AM   #5 (permalink)
Rapid Rob's Avatar
I've been watching this thread hoping to find some shocks for my Pilot, but the options are slim. Not much of a choice for these cars.
Anyone know of a site with a good choice? Can't find any springs, either.
