Brake Fluid Flush - Honda Pilot - Honda Pilot Forums
Old 08-14-2005, 12:44 PM   #1 (permalink)
Cali_Pilot's Avatar
Default Brake Fluid Flush
Does anyone have the instructions for flushing out the brake fluid? I did a search and didn't find anything helpful. Thanks!
2003 Honda Pilot EX Sandstone Metallic
Rear Splash Guards
Goodyear Fortera w/SilentArmor tires
Full Sized Spare
Tornado Fuel Saver
K&N Air Filter
Catch-All Front Floor Mats
AstroStart 2205U Remote Starter
HU: Pioneer AVIC-Z1
Clarion OHM102 10.2" Overhead Monitor
F. Speakers: Infinity Reference 6000cs
R. Speakers: Infinity Reference 6012i
Speaker Amp: Profile AP1040 (80X4)
Subwoofer: PowerBase Xtreme ES10D
Subwoofer Amp: Jensen 200W RMS
Dynamat Xtreme: 4 Doors+ Sub Location
Cali_Pilot is offline   Reply With Quote
Old 08-14-2005, 01:23 PM   #2 (permalink)
Never Say Die!!!
Same as bleeding the brakes, just pump and watch until new fluid comes out. And MAKE SURE the master cyl does not empty
nolan65 is offline   Reply With Quote
Old 08-14-2005, 01:24 PM   #3 (permalink)
Default Re: Brake Fluid Flush
It is the same procedure as bleeding the brakes.
The difference is first you siphon as much fluid out of the reservoir as you can and replace with new fluid.
Then you bleed the brakes till you get clean, clear, new fluid at each wheel.
Some find it easier to do by changing brands of fluid so they can see the color change easier.
ATE makes a regular DOT4 and a Racing DOT4 that are really the same except for color.
