Replaced rear rotors and pads at 36k miles!! - Honda Pilot - Honda Pilot Forums
Old 04-25-2005, 02:20 PM   #1 (permalink)
Default Replaced rear rotors and pads at 36k miles!!
Just had my rear rotors and brake pads replaced by a local mechanic because the right rear outside pad was metal on metal. Ruined the right rear rotor. Replaced both rear rotors and pads. Called dealer that sold me the Pilot and they sold that's a wear item. Seems way to fast for the rear brakes to be replaced/fixed!! Need to go to the next level. Anyone have a number for Honda that I can call directly. Anyone think I'll have any luck covering this under warranty from Honda? I have kept the parts from the mechanic for show and tell.
'03 EX-L, Redrock Pearl
habsfan is offline   Reply With Quote
Old 04-25-2005, 02:38 PM   #2 (permalink)
GreenMachine's Avatar
That's way too fast for the rear brakes to need replacement, unless you drove around with the parking brake on. Sounds like you had a frozen caliper. Did you ever have it serviced at a dealership before because it seems they should have noticed how much the rears had worn?
As for whether you will collect, doubt it, but it certainly doesn't hurt to try. Good thing you have the parts too, that can only help.
Good luck.
Old 04-25-2005, 03:03 PM   #3 (permalink)
Default 12 months/12,000 miles
Also, when I spoke to the Honda Service guy he stated the brakes are only covered under warranty for 12 months/12,000 miles. Don't have my warranty manual or owners manual in front of me. Is this correct?
Old 04-25-2005, 03:11 PM   #4 (permalink)
MG Pilot's Avatar
Default Re: 12 months/12,000 miles
That's correct-
'03 Starlight Silver EX-L...Rear Splash Guards, Cargo Tray, All-Season Mats (Husky Liners In Front), Trailer Hitch, 3M Clear Nose Mask, K&N Performance Air and Oil Filters, Mobil1 5W-20 Oil, Sylvania Silver Star Bulbs, FS Spare, Michelin X Terrains, Bosch Micro Edge Excel Wiper Blades, Amsoil ATF, Bosch Premium Oil Filters, Purolator PureONE Oil Filters, Fumoto Oil Drain Valve, Akebono Ceramic Pads, Brembo Rotors-
MG Pilot is offline   Reply With Quote
Old 04-25-2005, 05:11 PM   #5 (permalink)
I agree, but that doesn't mean they won't look at your case. I understand that rotors and pads are wear items, but a frozen caliper may not be considered a standard wear item. Definitely give it a shot.
Old 04-26-2005, 12:11 PM   #6 (permalink)
RFM
RFM's Avatar
Default Re: Replaced rear rotors and pads at 36k miles!!
Nope. Not a chance unless you can show a defect in the parts.
<font color=006200><b>2005 EX-L/NAV Sage Brush Pearl.</b></font> 11/13/04
OEM cargo tray & cover, splash guards, and ventvisors; WWong's center pads and nav screen protector.
RFM is offline   Reply With Quote
Old 04-26-2005, 02:11 PM   #7 (permalink)
Go BGSU Falcons
Default Pads
The wear is probably not that unusual. The Pilot has electronic brake distribution that distributes the braking from the front to rear more evenly depending on load and grade. This would most likely mean that the typical more wear on the fronts would be more distributed to both front and rear. I have replaced plenty of brake pads on different cars with no more than 36,000 miles on them.
04 Starlight Silver Pilot EX
pilotbob is offline   Reply With Quote
