rear wiper - Honda Pilot - Honda Pilot Forums
Old 03-18-2005, 08:29 AM   #1 (permalink)
Default rear wiper
I finally figured out how to remove the rear wiper yesterday, but I have two problems:
1) I was under the impression that the rear blade should 17" long (when I was ordering online). When I compare it to the factory wiper, it is longer by about 1" on each end. Is this OK?
2) I can't install it in the same slot on the wiper arm as the factory wiper was installed. That's because the part of the wiper where is snaps in place is perfect cyclindrical, whereas on the factory wiper is flat on one side, not to mention its thicker.
The new wiper won't hold in place. Did I get the wrong type of wiper? Has anyone purchased a particular brand, model, and size such that it was a perfect fit?
coeng73 is offline   Reply With Quote
Old 03-18-2005, 08:34 AM   #2 (permalink)
Olde Timer Administrator
colorider's Avatar
Default Re: rear wiper
You might try a search. Here is at least one thread on the subject of replacing the rear wiper.
Also moved thread to "maintenance".
'10 Honda Pilot EX-L
'11 Ford Mustang GT/CS
'12 Yamaha XT1200Z
Enjoy Life Today
Yesterday Is Gone
Tomorrow May Never Come
Old 03-18-2005, 08:51 AM   #3 (permalink)
colorider,
I did a search (before I posted) but could not find an answer specific enough for my question. The link to the thread that you provided was specific to the actual blade inserts. I want to replace the whole blade.
Old 03-18-2005, 09:01 AM   #4 (permalink)
colorider's Avatar
colorider,
I generally always try to just replace the inserts if possible since so many of the after market blades seem to be cheap knock-offs of the OEM blades. Only exception would be if I were installing winter wipers and in those case, I would re-install the OEM blades come spring.
Good Luck!
'12 Yamaha XT1200Z
Enjoy Life Today
Yesterday Is Gone
Old 10-14-2011, 12:59 PM   #5 (permalink)
Default Here's how I did it.
After searching for an answer to the question "how do I change the rear wiper" I came across this forum. It was all good information. I was so happy when I finally worked it out that I posted the solution on youtube.
If it's allowed to add links on this forum, this 1 minute video might answer a lot of people's questions. If it helps, let me know.
MrJDawg is offline   Reply With Quote
