LinkBack | Thread Tools |
Rating:
#46 (permalink) | |
You must have better access to parts and prices than I have. A rotor for $22???? I have never seen them on a modern car for less than $150. I agree with you if you can get them for $22. Please share your sources. Dobe |
#47 (permalink) |
![]() ![]() ![]() ![]() Join Date: Dec 2003
The last set I got for my '91 Accord from Autozone or Advance were less than $25. They were that cheap for my Civic also. Not sure about the pilots.
Roger Edit: Just looked on the autozone web site and they have front rotors for $62 (Duralast, 2 year warranty) or $132 (Beck Arnley, 3 month warranty). Roger Second edit: Advance Auto has a set for $25.99. Roger |
#48 (permalink) | |
#49 (permalink) | ||
This is from www.getcoolparts.com, which does free UPS ship on all orders over $50. Same thing with www.stopshopanddrive.com. Unfortunately, it doesn't seem like they carry any rotors (or any parts, for that matter) for the Honda Pilot at this time. Hopefully by the time I need them they will. I've called them and they've pulled through, however, on getting me stuff (like 4 Bilstein HD struts for my VW) Quote:
I rarely have seen them on a modern car for that much, at least not from my sources. The rears for the Passport, which is a very similar design as the Pilot's rear, cost $51 each, in Brembo brand. Fronts are $68. Those are made in Italy, sometime Mexico. Bear in mind, try to stick to brands such as Brembo or ATe, or some other "name brand." Stay away from the "Made in China" stuff. I have had very poor results with those, as the steel is very substandard.
#50 (permalink) |
Die Hard Day Hiker
To require a rotor change every brake job sounds a bit excessive.
My lexus rotor lasted me 130K miles.
Dan from SoCal Black LX, Tow Package, Mud Guard, Security system, Roof Rack, Tinted all windows, Bike Rack, DYI |
#51 (permalink) | |
Remember, this applies to the last generation VW Passat.
#52 (permalink) |
I am changing the rear pads this weekend...73K. Is it worth having the rotors turned?
'03 Starlight Silver EX-L...Rear Splash Guards, Cargo Tray, All-Season Mats (Husky Liners In Front), Trailer Hitch, 3M Clear Nose Mask, K&N Performance Air and Oil Filters, Mobil1 5W-20 Oil, Sylvania Silver Star Bulbs, FS Spare, Michelin X Terrains, Bosch Micro Edge Excel Wiper Blades, Amsoil ATF, Bosch Premium Oil Filters, Purolator PureONE Oil Filters, Fumoto Oil Drain Valve, Akebono Ceramic Pads, Brembo Rotors- |
#53 (permalink) |
Looper - Pro Jock
It may be worth turning the rotors, but make sure you do it somewhere reputable. If they do not know what they are doing, they will often screw them up and then tell you that they need to be replaced because they are "warped."
Not sure where people on here get their rotors turned.
---- Peace, Matt 2006 4WD EX-L w/ Navi 1998 Chevy Malibu LS POS 2001 Pontiac Aztek GT (Sold) 1995 Nissan King Cab V-6 (sold) |
#54 (permalink) |
I have had good luck going to a NAPA store that has a machine shop.
06 Steel Blue Ridgeline RTL S/R with tow and fogs. A former 03 Standstone LX-RES w/towing package, x-bars, rear mud flaps, Husky floor liners, cargo mat, Delphi SkyFi XM Radio and Michelin Cross Terrains with full size spare that served me well for over 51K miles. I steer a hydrostatic Honda Harmony HRB215HXA, roto-till with a Honda FG110 and peddle a Honda Trail Pilot bicycle. |
#55 (permalink) |
Mosquito Mechanic
Great Thread! Thanks for putting it together!
I've been doing Brakes jobs on cars for many years. I had never heard of opening the bleeder. Thanks for the tip to open it!! I guess I've been lucky all these years of pushing fluid back into the reservoir. What the torque value is for the caliper bolts and the caliper bracket bolts? Thanks for the help! GFB
+++===========+++ 2003 Pilot EXL-RES 2011 Fit Sport ![]() 2004 2500 Ram Diesel Yaesu FT-8800r ---------------------------- Going Where everyone has gone before... |
#56 (permalink) | |
![]() ![]() ![]() Join Date: Oct 2003
I've had a few pair done at O'Reilly Auto Parts (Plano, TX) and all have gone well. Just a comment on Pilot brake bleeding... I notice the position of the bleed screw is high on the caliper, obviously put there to prevent capturing of air. When open, fluid dribbles out slowly. This shows a positive flow of fluid from the fluid reservoir to the bleed screw. I changed my brake fluid by going around to each screw, opening it up, attached a 12" clear rubber hose, and pumped fluid through with the brake pedal until it appeared lighter in color in the clear rubber hose. This took about 4-5 pumps per brake. But when not pumping, fluid still dribbled out. I never let the reservoir run dry. Years ago when doing brakes, I had to have someone slowly push the brake pedal while I tightened the bleed screw, to ge the air out. There was no positive flow when the bleed valve was open. So if we have this positive flow, why do we need to use bleeder kits? I did all four side this way and had no air trapping problem - brakes are solid as a rock. Also, I was at 45K miles and my brakes were pulsing / grabbing when stopping. The guy who turned the rotors said he only took off .001 on each side, and they cleaned up completely - so they really were not warped, which surprised me. I installed Wagner MX943 pads and it really stops well now - no pulsing anymore. They seemed expensive to me, $58.99 for a set. "Oh well" - look what I saved. Thank you for the post on how to get the rotor off! I would have not noticed the two small screws. I was about to go after the axle nut to remove the rotor!
2003 Pilot EX Sandstone Metallic, Mud Flaps, Cargo Tray, Cargo Net, Locking Wheel Nuts, Running Boards, Mfg 08/03 |
#58 (permalink) | |
What should I have done if the impact screwdriver failed? Also, once these puppies are removed, the front calipers didn't just slide out! They were also impossible to pul out! |
#59 (permalink) | |
Torque these bolts to 79.6 lb-ft (as per the Helms manual). Torque the flange bolt to 27 lb-ft For more info: Another Brake DIY on this forum |
#60 (permalink) | |
Wax will be pulled into the screw and threads as it cools. The hammer blows will create microscopic fractures in the rust on the screw, and it will eventally break. The wax will then lubricate the threads somewhat. First oil change at 6500 miles I applied anti-seize to these tiny screws, because I predicted that 5 years from then, I would be cursing these screws for being so hard to remove.
