LinkBack | Thread Tools |
Rating:
#227 (permalink) |
Okay, this evening I gave gravity bleeding a try on my wife's 04, and for whatever reason it was just a no-go. I don't know why, but the fluid just would not flow on it's own. I ended up having my 4-year-old work the pedal for me while I worked the bleeders.
To be honest, I'm kinda disappointed. |
#229 (permalink) |
This could be the reason the fluid would not flow. It did come out and make it's way to the cup. But once the cup got about 1" of fluid in it, it just seemed to stop (or slow WAY down). I waited about 15 minutes (or maybe more) before I gave up.
#231 (permalink) | |
You can order the OEM 12oz bottles on ebay for $5.75/ea shipped (just search "Acura DOT-3"), but it's shipping from North Carolina. You can also call your local Honda & Acura dealers to ask how much if you'd rather just pick it up. Usually the local dealers are a little more than ebay + sales tax. acura dot-3 | eBay Last edited by 94eg!; 11-03-2011 at 11:50 AM. |
#232 (permalink) |
Great thread. I replaced all 4 rotors and pads yesterday on our 2004 Pilot. I decided to go with Centric premium rotors and centric ceramic pads. For those that aren't aware, Centric owns Stoptech. The rotors had black paint on the hat and edge for anti-rust. They looked really good. I bought them all from Amazon for $262 shipped. I performed the bedding in as per their recommendations (a series of very hard 45mph to near 0mph stops) and am VERY impressed with stopping performance. Maybe it's in my head, but they feel like they stop better than the OEM set.
I also flushed the brake fluid with OEM fluid using a suction brake bleeder (connected to my air compressor) I bought from Harbor Freight. It was a breeze doing it that way.
04 Pilot EX-L + NAV |
#233 (permalink) |
Centric makes awesome stuff. I recently used the Centric premium rotors, Stoptech pads and Stoptech stainless lines on my Civic. Outstanding fit and finish. The rotors are e-coated and fully balanced and inspected. You can find a lot of centric dealers online for ridiculous prices. I got my Integra rotors and pads for about $28 each + coupons.
BTW: I spent some time talking with the guys at the stoptech booth at SEMA this past Friday. They were great guys, and those big 4 & 6 piston brake setups look even more amazing in person (especially the anodized trophy calipers). Wish I could afford that stuff on my cars. Last edited by 94eg!; 11-06-2011 at 11:07 PM. |
#234 (permalink) | |
A couple quick question if I may. Can this be done to do a complete fluid replacement, and if yes, how long will the fluid take to drain out on each line (I expect the rears will take a fair bit longer). What's the hose size? I replaced the pads on my Pilot a couple days ago (which was super easy to do), and was going to get the dealer to do a brake fluid flush, but if I can do it myself I'd rather go that route as it'll give me something to do. Thanks.
2007 Pilot EX-L Navi AWD HID lights Towing Package Read Mud Guards Cross Rails Chrome Side Steps USA Spec iPod Adapter AW Floor Mats Rear Cargo Liner Interior Wood Trim WW Interior Pads Full Sound Proofing Polk DB650 Front Speakers Extended Warranty Paint/Fabric/Undercoat Protection Michelin Latittude |
#235 (permalink) |
If you keep reading past that post you will find that gravity bleeding doesn't work on the Pilot. I could not get the fluid to flow. You will need to have someone work the pedal while you work the bleed port. Have them hold pressure on the pedal. You open the bleed port, let the fluid flow out, and close the bleed port. Then tell them to let go and do it again. Repeat till you see clean fluid coming out.
#236 (permalink) | |
Thanks for the reply.
#237 (permalink) |
One thing I noticed after changing the pads is that I removed a bit of fluid and then the brake and VTM lights illuminated on the instrument cluster. The difference between not enough and just right seems like a couple teaspoons.
#238 (permalink) | |
It is best not to goo too much further then the normal stroke range used for breaking. The inside of the master cylinder is kept nice and clean from using the brakes. Pushing to beyond the point that is normally (or even occasionally) whipped during normal use will subject the seals to the much rougher surface where corrosion may exists and lead to early master cylinder failure.
#239 (permalink) | |
X2, Honda actually put that in writing in one of the service bulletins. I used to to think it was more a wives tale until I saw that. Found it. Last edited by carguy07; 02-11-2012 at 04:18 PM. |
#240 (permalink) |
If you disassembled master cylinders to rebuild them, you KNOW it is for real.
I always push my peddle to the floor once in a while, so (in theory) the corrosion never has a chance to start. Not hard to do while sitting at a light about once a week or so.
