Fumoto oil valve - Honda Pilot - Honda Pilot Forums
Old 01-04-2005, 06:37 PM   #1 (permalink)
Tuck & Jack's Avatar
Default Fumoto oil valve
I've searched for this, but cant figure out all the details on. I think i need a F-106 w/ two ADL-106 adapters? is this true? and what about the nipple version, some thought it might stick out too far and get a cross member wet? Who has them, and do you like them?
Tuck & Jack is offline   Reply With Quote
Old 01-04-2005, 07:29 PM   #2 (permalink)
You have the correct configuration, I don't have the 1 with a nipple. It does take 2 adapters to clear the recessed oil pan. I have 1 on the Pilot, 1 on my CRV and 1 in the garage to put on my mother's CRV. It makes changing the oil a breeze. Well worth the cost.
Old 01-05-2005, 12:29 PM   #3 (permalink)
I have an '05, so I'll assume nothing on the oil pan has changed.
Old 01-05-2005, 08:25 PM   #4 (permalink)
hitecdan's Avatar
I'll second that. No more fishing out an oil plug that fell into the pan accidentally and having to replace the sealing washer.
I managed to get the whole thing on with one adaptor.
2003 Honda Pilot EX DVD-L Tow Package
1990 Honda CR-500
2003 Ford F-350 6.0L PSD Tow Monster
hitecdan is offline   Reply With Quote
Old 03-04-2006, 07:25 PM   #5 (permalink)
ncelk's Avatar
I put one on our Ody today and it worked well with the adapter.
I am hoping that I can get it on the Pilot at our next oil change using the adapter.
I have heard others say they had to use 2 adapters. I don't really want to go that route.
ncelk
2009 Toyota Camry Hybrid
2002 Mazda Miata SE
2006 Acura MDX Touring
ncelk is offline   Reply With Quote
Old 03-04-2006, 09:24 PM   #6 (permalink)
tangotango99's Avatar
Can we have a picture the valve installed ?
Old 03-04-2006, 10:45 PM   #7 (permalink)
ncelk's Avatar
I'll snap one tomorrow as it is on our Ody....................
ncelk
2002 Mazda Miata SE
Old 03-05-2006, 02:59 PM   #8 (permalink)
ncelk's Avatar
Here are few of the valve installed............
ncelk
2002 Mazda Miata SE
Old 03-05-2006, 03:00 PM   #9 (permalink)
ncelk's Avatar
Another.........
ncelk
2002 Mazda Miata SE
Old 03-05-2006, 03:01 PM   #10 (permalink)
ncelk's Avatar
3rd one.......sorry about the quality...........I could only reach so far under the van.
ncelk
2002 Mazda Miata SE
Old 03-05-2006, 03:01 PM   #11 (permalink)
ncelk's Avatar
4th.........This shows it closer where it mounts to the oil pan.
ncelk
2002 Mazda Miata SE
Old 03-05-2006, 03:02 PM   #12 (permalink)
ncelk's Avatar
The whole assy........
ncelk
2002 Mazda Miata SE
Old 03-05-2006, 03:03 PM   #13 (permalink)
ncelk's Avatar
Last one..........note that the opening spring is up completely out of the way. No way road debris is going to hit it........not that I was concerned about it anyway. This appears to be a pretty sturdy, well built piece.
ncelk
2002 Mazda Miata SE
Old 03-05-2006, 03:05 PM   #14 (permalink)
ncelk's Avatar
Note that I had to use an extra Honda crush washer to get the positioning that I wanted on the lever.
I did this oil change yesterday and check it for leaks every time I have driven it and you can see that it looks pretty good underneath so far.
Now if there was a cleaner way to do the oil filter (with less mess).
Also, these photos were taken with the camera flat on the ground underneath the van, so these photos are looking from the floor straight up at the bottom of the oil pan.
ncelk
2002 Mazda Miata SE
Old 03-05-2006, 08:59 PM   #15 (permalink)
Default Re: Fumoto Oil Drain Valve
I'm confused
How many adaptors do you really need for the Pilot?
One or Two?
I've read a fellow-member's post saying one.
I just want to be sure before placing the order.
2004 Honda Pilot EX-L: Nighthawk Black Pearl: Date Built: July 26, 2004/4:57am
Date Acquired: Sept. 06, 2004.
Aru4mie is offline   Reply With Quote
