15K (1 Year) service - Honda Pilot - Honda Pilot Forums
Old 10-26-2004, 01:54 PM   #1 (permalink)
btk467's Avatar
Default 15K (1 Year) service
Hi all,
I am going to do the 15K (1year) service as DIY.
Thank you all, I know how to do it.
There is one question.
What is the difference between "service front and rear brakes" and "inspect front and rear brakes"?
Has someone done this service as DIY?
Sorry, could find a link to thread about service brakes.
Thanks.
2008 Pilot SE-RES: chrome package, protection package, digital MP3 changer, Backup sensors with LCD monitor, roof rack, hood protector
2007 Honda Fit Sport AT Orange : OEM mats
2006 Honda CR-V EX-L Traded
2003 Honda Pilot EX-L Traded
2002 Honda CR-V EX Traded
2000 Honda CR-V LX Traded
1999 Honda Civic LX Traded
1992 Toyota Tercel Sold
btk467 is offline   Reply With Quote
Old 10-26-2004, 03:20 PM   #2 (permalink)
Superior Honda Tech
hondaman2's Avatar
inspecting brakes has to do with checking the wear and determining if they need to be replaced.
servicing has to do with changing the front brake pads or rears, at the same time testing the caliper pistons and adjusting the parking brake. Sometimes a brake bleed and a rotor turning.
with 15k you will not be servicing the brakes it is just an inspection. AT around 45k you will be needing front brake pads. The rears last around 150k+.
Former USMC Sgt. 10 years
Old 10-26-2004, 04:19 PM   #3 (permalink)
btk467's Avatar
hondaman2,
thanks a lot.
Old 10-26-2004, 05:52 PM   #4 (permalink)
dbudds's Avatar
Default I just had them
Change the rear diferential fluid and oil.
dbudds is offline   Reply With Quote
Old 10-27-2004, 03:38 AM   #5 (permalink)
hondaman2:
I have just under 20K miles and I get a shimmy under braking. Feels like at least one front rotor needs to be turned already. Is this common? It is going in for trans recall soon.
2004 Silver Pilot EX-L-RES
Michelin CTs
Honda tow pkg
99 Coleman Westlake Tent Trailer
Airlift 1000 air bags
Thule Evolution 1600
Infinity 6002si
rshelar is offline   Reply With Quote
Old 10-27-2004, 08:34 AM   #6 (permalink)
The pilot is a very heavy vehicle, it is not uncommon to have a warped rotor due to the heat buildup under hard braking with this vehicle. I've not found Honda or Acura rotors to be particularly durable during heavy braking.
I had a warped rotor on my Acura TL from one emergency(Well not an emergency, but I had to stomp on the brakes due to a radar trap..). A simple turning of the rotors fixed it quite well.
04silver is offline   Reply With Quote
Old 10-27-2004, 09:11 AM   #7 (permalink)
humanum est errare
Originally posted by rshelar
hondaman2:
A few other members have reported premature rotor warpage, so your experience would not be uncommon.
David
2009 Sienna XLT Limted AWD
2006 A4 2.0 CVT
2004 X3 3.0
2003 M3Cic
2003 325i (gone)
2003 Matrix XR (total loss)
1996 Landcruiser (gone)
Old 10-27-2004, 03:20 PM   #8 (permalink)
Superior Honda Tech
hondaman2's Avatar
it is not uncommon...it really all depends on how much braking you do.
constant stop and go...
I have a friend who lives in Big Bear(for all you Californians)(elevation 6000 ft +) and commutes to Barstow everyday. He was having rotors turned about every 6 to 8 months. I put on some high quality drilled rotors and its been about 18 months since he has needed any brake work.
Quality of brake pad is also a factor...get some sort of thermo quiet pad and there will be no noise and longer life.
you should know that the thinner the rotor the faster they warp...so the more times the rotor is turned the faster it wears out and thereby needing to be turned again.
also rear brake adjustment and parking brake adjustment are a factor. If the rear brake shoes are loose(out of adjustment) the front brake pads are going to be doing most of the work and so you see here again that the rotors are going to be getting hot and staying hot longer than necessary. Parking brakes and rear brakes go hand in hand if one is out of adjustment so is the other.
the last thing to take note of is brake fluid. If you have dirty brake fluid in the master cylinder then it is in the lines. And if it is in the lines it is in the caliper. Dirty fluid in the caliper inhibits the caliper piston from moving properly and therefore requiring more pressure, more pedal and distance for stopping.
FYI.. when you get a brake service make sure that the place you go to does not compress the caliper piston with the bleeder valve closed(a lot of places do). What happens is when the piston is pressed back into the caliper all the fluid behind the piston is forced back into the master cylinder the wrong way. The dirt that is in the fluid gets lodged between the master cylinder push rod and the seal...then you get a mushy pedal and then you lose your brake pressure.
well thats all for now, if I can think of more I will let you know.
Old 10-27-2004, 04:28 PM   #9 (permalink)
Rip Tide Dude!
john802's Avatar
Make sure to put one end of tubing in the bleeder screw outlet and the other end in a bottle/container before compressing the caliper piston or else you will be spraying dirty brake fluid all over.
