vibration/chatter issue - Honda Pilot - Honda Pilot Forums
Old 01-22-2012, 10:03 PM   #1 (permalink)
Default vibration/chatter issue
I recently purchased a 2005 Pilot with 95,000 miles. I've noticed a vibration or chatter at times with the vehicle. It's most noticable when cornering during an accelleration 20-25 mph. As the weather got colder last week, it was more frequent. Seems to get better as the vehicle warms up. The dealer replaced the Rear Differential fluid, but that didn't fix it. Mainly there when accellerating into a turn from a stop, then goes away as I hit a straight stretch. Any ideas? Engine mount? Transmission?
ebuss is offline   Reply With Quote
Old 01-24-2012, 10:27 AM   #2 (permalink)
Hap
does it sound like you are going over a rumble strip only quieter? It could be your torque converter
Hap is offline   Reply With Quote
Old 01-24-2012, 10:54 AM   #3 (permalink)
Since it is in corners and when accelerating, I would go with a wheel bearing, a hung up caliper, a bad transmission or engine mount, before the Torque Converter problem.
Old 01-24-2012, 08:32 PM   #4 (permalink)
Took it back to the dealer today for the chatter issue. I felt the chatter probably 6 times on the way there. With the mechanic sitting next to me, it would not do it.!They took it for sevaral rides today and couldn't replicate it, so I was sent on my way with no resolution. I'm taking it to my local trusted mechanic on Friday. Is there any way to know if the TC is bad, other than pulling it out? After reading all the problems with Pilots, I'm afraid to take it on a long trip.
Old 01-24-2012, 08:46 PM   #5 (permalink)
Leave with dealership especially if the event occurs most frequently when the car is cold.
If you think it's the tranny, my universal recommendation applies, change the fluid.
Assume of course that the chatter Isn't as a result of traction control kicking in as a result of over enthusiastic throttle usage.
Old 01-24-2012, 10:16 PM   #6 (permalink)
The test for the TC is to find a very flat and level road.
Set the cruise control at 35, 40, 45, and 50 and see if you feel it when letting it maintain the same speed for about 1/2 a mile.
Old 01-27-2012, 04:54 PM   #7 (permalink)
Well, my local trusted mechanic confirned my worst fears. It's the transmission. He can make it repeat the symptoms every time. Strange that the dealership (who's on the hook for the fix) couldn't find anything wrong with the vehicle after having it for an entire day. Now comes the fun! To anyone out there looking at a higher mileage Pilot, buyer beware is all I can say. Test the heck out of it. Mine felt beautiful during the test drive.
Old 01-27-2012, 05:25 PM   #8 (permalink)
xGS
xGS's Avatar
First change the transmission fluid, then try replacing the pressure switches.
Sporadic vibration at low speeds
DIY: Replacing Transmission Pressure Switches
