Replacing the PCM in 05 Pilot EX - Honda Pilot - Honda Pilot Forums
Old 01-16-2012, 02:15 PM   #1 (permalink)
Vypre's Avatar
Send a message via Yahoo to Vypre
Default Replacing the PCM in 05 Pilot EX
Has anyone had any experience with replacing the PCM in their pilot themselves? Looks like mine has crapped out and I am more than likely going to purchase a used one vs paying about $1200 for a new one. Really just looking for anything i may need to know outside of unplugging the connectors and removing the bolt, repeating in revers order..... Thanks.
HU: Factory
Front: Pioneer TS-D720C Component 6 3/4" - 4 ohm
Rear: Pioneer TS-A642P Coaxial 6.5" (4 way) - 4 ohm
Sub: Rockford Fosgate Punch P3SD210 10" DVC - 2 ohm
Sub Amp: Viper D600.1 750W (mono)
4 ch Amp: Pioneer GM-D9500F (class D, 4 ch) 2~8 ohm 800watts
Accessories: Scosche SLC4 Line Out Converter (4 ch)
Phoenix Gold TLD66 Line Driver (6 ch)
Vypre is offline   Reply With Quote
Old 01-16-2012, 03:33 PM   #2 (permalink)
94eg!'s Avatar
Isn't there issues with the immobilizer? I think the ECU, Ignition switch & Key all have to match for the engine to start. You may want to talk to a dealer tech (not the service writer) about this before you drop money on an ECU.
