Smelling fuel from left side of engine manifold - Honda Pilot - Honda Pilot Forums
Old 01-03-2012, 05:37 AM   #1 (permalink)
HAK
Default Smelling fuel from left side of engine manifold
Help Needed,
Change the knock sensor harness for pilot 2004, re-used gasket.
Had some issues with injectors, # 6 came out re-fitted. not seeing any leak from # 6 injector.
Can it be the gasket is leaking because I did not turq it correctly.
only smelling gas, not seeing any fuel leak. Engine perfromance sweet.
When I complete installed and test, all work fine.
After some driving and the cold weather, smell started.
Help
How do I test or check where the smell is coming from
HAK is offline   Reply With Quote
Old 01-07-2012, 07:20 AM   #2 (permalink)
HAK
A bit of advice to Honda pilots folks.
Find a way to work around fuel rail for the injectors, either when you are changing the knock sensor harness or knock sensor its a pain.
I am getting gas fumes, and I don't know where its coming from.
Is there a tool to pick-up the where its coming from?
