Hi forum,
I have a 2004 Pilot that is exhibiting an occasional, intermittent brake light (only briefly, never seems to last a long time). It seems like I have noticed this mostly when cornering at higher speeds. I couldn't find anything on a search that seemed related. Any suggestions for possible adjustments (emergency brake seems like a possibility), or diagnostics to determine what might be the root cause? Thanks in advance... |
The important question is "why is your brake fluid low"?
Your brake fluid light is designed to be the first warning that either A: Your brake pads are worn......or B: You have a fluid leak somewhere. You should get in there and check the system out. If nothing is wet, then your pads are probably going to be on the thin side. |
