LinkBack | Thread Tools |
Rating:
#76 (permalink) |
I was able to contact American Honda today for the AC humming noise. I spoke to the customer service line and was provided with a case# N012013-02-1501716. I was surprised that this # is different from what the Honda dealer obtained for me (#3299098) from Honda tech support line in June 2012. Maybe the tech line and the customer service use different numbers? Anyone has any blue?
#78 (permalink) |
Glad to see the experiment worked and thanks for being the guinea pig. I plan on applying the fix to mine when it gets a little warmer.
From your pics, it looks like you used a piece of open cell foam pipe insulation for the padding. You might want to try the neoprene type insulation. It's closed cell foam and may work a little better. Another alternative is to use some sort of gel padding (e.g. cut up a Doctor Scholl's gel insert).
#79 (permalink) | |
#80 (permalink) |
I got an update from American Honda today for the "permanent fix" to the AC humming noise. My Honda Dealer called me yesterday and American Honda called me today. They told me about the same update- the formal fix will be soon released (possibly in 1 to 3 months) as their engineers are still working on that making sure the fix would be "permanent". This is what they told me but there is not a specific date for the release. Anyone got the same update from Honda too recently?
#81 (permalink) |
That sounds kind of vague. Kind of like: Did I tell you I have a time machine. It's curently broken and is stuck on current time. It will be fixed sometime but I can't tell you when and I can't tell you how it works.
#82 (permalink) |
mudbog, I hear you and agree with you. I guess all we can do is to keep calling them every month. Other than that what else can we do?
I now have to put my "temporary fix" back to its original construction. I received a recall latter from Honda today regarding the driver side airbag issue on pilots 2009 -2013. I just don't want the dealer to say that my fix for the ac noise could void the warranty if they see it. It might be better for me to do the "temporary fix" again after the airbag recall work is done by the dealer. |
#83 (permalink) |
After 6 months of fighting, I am finally done with my 2012 Pilot that makes (made) this obnoxious noise from the power steering pump. I succeeded in winning a Florida Lemon Law complaint, and Honda was forced to buy the car back from me. Glad to be done with this nightmare. Shame on Honda for not fulfilling their warranty obligations, and for handling this situation in the worst possible way. This was my third Honda in a row...will be my last.
#84 (permalink) |
2012 EXL 4WD. I have what appears to be the compressor / fan cycling with noticeable annoying hum and vibration every 10 seconds when its warm outside. It didn't happen all winter, but on the first warm day of spring the hum/vibration returned instantly. AC was off. Does the compressor turn itself on/off regardless of climate control settings? Or perhaps the second fan kicks in to cool the engine regardless of whether the AC compressor is on. In other words, maybe the AC compressor has nothing to do with it. Perhaps its just the second fan unit coming on/off that cause the vibration/hum. In any event, its bad and not acceptable. Will press the dealer on it next time I am in.
#85 (permalink) | |
#86 (permalink) |
Had my 2012 EX-L at the dealer for this issue. They said Honda is making new power steering and A/C brackets and they should be available in 6-8 weeks.
They'll call me when they are available... |
#87 (permalink) |
Is it just me or is Honda just being very lazy and slow. To take more than a year to address this issue is just ridicules not to mention design a car with this issue in more than one model year. How are they not catching things like this during testing and development.
#88 (permalink) |
Update: After reading the repair order, they're updating the power steering reservoir mounting bracket only...they did talk to Honda Engineering and got a case number.
#89 (permalink) | |
All along I simply wanted Honda to fix the problem, but they never once even attempted. They genuinely seemed surprised that someone stood up to them and didn't back down. I will say, I've ridden or driven 5 different 2012/2013 Pilots now, and they all have what I consider somewhat noisy power steering, but there are varying degrees of noisy. Mine was certainly the worst of the 5. When the conditions were right, a resonance effect set in and it got loud. It only happened when it was hot outside (hotter than 75-80 degrees)...which means most of the time for me. I would recommend looking into your state's lemon law. Usually the first step is just submitting a request for mediation form to document the problem and attempts to repair. Even if you don't take it any further, at least the complaint is getting registered outside of American Honda. |
#90 (permalink) |
I have been reading this message board since last year as I have the same issue. I had a 2011 Pilot Touring which did not make the noise, traded it in and got a 2012 Pilot Touring that does. It is very irritating. I live in Florida and I use my AC 98% of the time. The dealership did replace the fan initially, and I took it back, then Honda said that they were aware of the problem and working on a fix. As many of you I paid over 40K for a car that irritates me when I hear that nose (love otherwise).
When I did my oil change I gave the dealership great reviews, but Honda bad (it is ridiculous that this is going on for a year). The dealership called me because of the review and called Honda for me. I have not called Honda myself as looking at these posts shows no update. So should I call Honda directly? I assume if the dealership called they have a record of my car. Is there a phone number I should use? I live in Florida and I wonder if I should just go ahead and do what FL38 did and file a complaint? Is that a long/time consuming process? It sounds from the last few posts there may be a solution around the corner, not sure. I don't look forward to our Florida hot summers and this noise :-). Thanks! |
