Flap/Vibration noise around 40mph - Honda Pilot - Honda Pilot Forums
Old 11-23-2011, 08:32 AM   #1 (permalink)
Exclamation Flap/Vibration noise around 40mph
I would say that most of the time at roughly 40mph, around the transitition of 3rd gear, a vibration or flap noise becomes apparent for about 2-3 seconds and never longer. It doesnt do it at any other speed and is a bit mind boggling. It doesn't do it every single time, and the noise is not very loud but noticable. It sounds almost like when you put a baseball card on the front tire of a bicycle when we were kids to get the flapping motorcycle sound.
Also, I have been told that in roughly ~10,000 I need to replace the timing belt. Not sure if this has anything to do with it but I just thought I would throw it in there. When I do replace the timing belt, would it be a good idea to go ahead and replace the water pump at that time?
VT_Piloteer is offline   Reply With Quote
Old 11-23-2011, 08:52 AM   #2 (permalink)
Underdog's Avatar
With the timing belt it's not a bad idea to do the water pump at the same time. An ounce of prevention is worth a pound of cure.
Dealing with your your noise. Are you sure your rear windows are completely closed? IF mine 04 Pilot are slightly open I get a buffeting noise at about that speed. Just a thought.
Another thing to check is are your roof rails tight?
Good Luck
Underdog is offline   Reply With Quote
Old 11-23-2011, 09:14 AM   #3 (permalink)
Yes, the sound is without a doubt coming from the engine and the windows are always up in the back due to the buffering sound. I do think i will replace the pump too but I can't expect to pay any less that $500 for it. I wouldnt go as far and say that it was a grinding noise but more so as it you run over the rumble strips for a brief second at 40mph.
